Delay Compensation value with UAD
trying to understand the Protools value (in the mixer)
------------------------------------------------------------- from the UAD manual Some UAD plug-ins introduce additional latency to achieve sonic design goals (for example, upsampling). When these UAD plug-ins are used in a DAW, additional latency is induced in the signal path. Therefore, they require more compensation to remain perfectly synchronized with other tracks. Although the latency added by these UAD plug-ins is negligible (typically between 0 – 300 samples ------------------------------------------------------------ when I insert a simple 1176, PT shows a delay compensation of 1079. When using Studer Tape it's 3000 something. Why is UAD talking about 300. Any way to optimise ?
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32 |
Re: Delay Compensation value with UAD
If you are using a PCIe or Thunderbolt UAD device, then you can enable LiveTrack Mode. It will come at a bit of a hit to your CPU usage, but it disables extra UAD based buffering.
If you are using the plugins during mixing, I wouldn't stress the extra latency - provided that it is within Pro Tools maximum delay compensation, it will be handled accordingly automatically.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
thank you. yes, it's PCIe.
It is for the same reason that the Apollo Console app stops users from using some specific plugins all together. The ADC limit is related to the abilities of HDX DSP. Using UAD plugins is a little bit of a worst-of-both-worlds in that sense - it will chew up delay compensation, or hit your CPU harder to avoid it. AAX-DSP and native plugins don't have the same drawbacks... mostly.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
Best case is to track with Native and then mix with UAD....while running the ADC number up (Buffer as well) as high as you can get it
PT used to act funny when there were multiple layers of Auxiliary tracks being fed to auxiliary tracks. It made its ADC go haywire...(caveat is i don’t remember when it was) but since then I have been aware to make my routing as simple as possible and assume PT needs it this way. It will or can eliminate problems
How do we adjust the ADC in Pro Tools to make up for the latency in the UAD Plugins ?
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz Macbook M2 Pro macOS 14.4.1 Pro Tools 2024.3.1 Logic Pro X Reason 12 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
UAD plugs LiveTrack Mode with PT HDX system
H----
Similar question here....I just received a free UAD-2 QuadCore PCIe card and my first UA plugs with my purchase of the outboard UAD 4-ch tube preamp. I run an HDX system, so when live tracking I like to use some channel strip plugs. I have to use DSP plugs as Native plugs are unavailable when recording. But the only DSP plugs I own are the stock Digi stuff and some Metric Halo, which are serviceable but not special. I was eager to see if somehow my new UA plugs could be used in UA’s LiveTrack Mode, in hopes they could replace my DSP plugs. But, there’s really no way, is there, as all these UA plugs are Native, and any Native plug is forced into bypass when in record mode? MacPro 5,1 OS 10.12 PT 12.8.3 HDX 16ch A/D interface |
Automation Delay With Delay Compensation On? | hbadger30 | Pro Tools 12 | 1 | 02-10-2016 01:07 PM |
help fixing plugin delay and delay compensation disaster | prestonhavill | macOS | 14 | 12-24-2014 03:35 PM |
Delay compensation with backline delay | chuck goodwin | VENUE Live Sound Systems | 3 | 08-09-2013 07:54 AM |
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing | CNSound | macOS | 1 | 01-27-2012 11:10 AM |
Delay compensation- choice of 'Medium delay'? | dtmprod | Pro Tools TDM Systems (Mac) | 2 | 05-05-2010 11:00 PM |
