Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 05-25-2015, 12:10 AM
Spyderrp7 Spyderrp7 is offline
Default Backing Up Hard Disks
Which is your favorite program for backing up your audio hard disks?
When you have lots of GBs of audio projects and you backup quite often (once in a week let's say), then you need a backup program to be able to do incremental backups. That way, the backup program will copy only the new and modified files, so the backup process is much faster.
So which is your favorite backup program for PC and Mac?
Old 05-25-2015, 02:51 AM
suicune suicune is offline
Default
I've been using CCC on mac. It's been working great, has some nice options (like archiving old files, setting custom drive & folder schedules, auto power on/shutdown) and is also handy for cloning bootable system drives when you need to upgrade your OS. It's very reasonably priced and has a full function demo so you can check it out properly before spending anything.
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
Old 05-25-2015, 03:01 AM
Default
CCC looks great and has a great price also. What about windows users? I think that CCC is Mac only.
Old 05-25-2015, 03:27 AM
Stig Eliassen's Avatar
Default
Agreed.
Old 05-25-2015, 08:32 AM
The Weed's Avatar
The Weed The Weed is online now
Default
For Mac, Avid in the past has recommended SuperDuper. For Windows, the Forum consensus has been Acronis True Image Home. However, while I use and recommend ATIH 2014 if you can find it, having used ATIH 2015 and experienced first hand the complete dumbing down of the program and how many things have been stripped out if it, I can't suggest that version to anyone. See this Thread. After doing some research, the closest backup program I can find to Acronis at a reasonable price is Macrium Reflect. I haven't tried it, but, when ATIH 2014 won't work anymore on whatever OS I have, I will. Another contender is Image for Windows.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 05-25-2015, 10:03 AM
anothercolour anothercolour is offline
Default
I use Intego Backup Manager Pro. It might not be as popular as other programs, but it does a fine job.
Old 05-27-2015, 01:49 AM
Natashastone Natashastone is offline
Default
my favorite backup program for PC is free AOMEI Backupper software,which supports both disk backup and partition backup. You can back up the entire disk or some partitions According to your specific needs. Thus makes the backup operation more flexible.Moreover this software can complete full backup, incremental backup and differential backup perfectly. i love this software so much.
Old 05-27-2015, 01:54 PM
c-tone c-tone is offline
Default
CCC is good for backing up entire disks, but if you just want to incrementally back up project files or folders (without cloning a whole drive), check out Synchronize X (Plus or Pro) by Qdea (Mac)
www.clifnorrell.com
Old 05-27-2015, 02:08 PM
Default
I don't want to backup the whole disk, why would I ever want to do that??? Just copy the new files.
Old 05-27-2015, 03:15 PM
Ben Jenssen's Avatar
Ben Jenssen Ben Jenssen is online now
Default
Because a disk image is different from an incremental backup, and it has advantages. An image is a bit-for-bit copy. Whatever the file system. It restores perfectly, doesn't care about file integrity or anything, it's just the exact bits.
I do both. An image once in a while, manually, and incremental bacup every night automatically.
As for applications, I'm on mac, and I use Disk Utility for images, and Timemachine for incremental. Both come with the OS and does the job. I shut off TM and use a free utility called Timemachine Editor to set a custom backup scheme. No need for 3rd party apps.
Added: I don't use disk imaging for my audio drive but for the boot disk, and TM on both. For example I create a disk image before installing stuff or upgrading in case something goes wrong.
Best way to organise Hard Disks? badagent1 Storage Subsystems 2 05-07-2009 02:55 AM
Backing up to DVD-RW disks Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-01-2007 05:16 PM
Does PTLE Run better with 2 Hard Disks? JasonGough 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-21-2005 10:42 AM
Hard disks. Help me please... poroto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-10-2004 11:08 AM
DMA on 'old' hard disks Flosskkii Digidesign Hardware & Software 3 03-25-2001 03:48 PM
