Old 03-16-2013, 01:19 PM
McLuckie McLuckie is offline
Default Bouncing Issues
Hi Everyone,
I really hope someone can help me out here. I am completely bamboozled by this problem. Thanks to everyone in advance that may have a solution.
I have just finished a remix in Protools. I have bounced it out analog outputs 1-2. Every track within my session is routed to outputs 1-2. When I am bouncing out I can hear the track perfectly.
However when I listen back to the bounced mix it's missing one thing, and that's my external reverb unit. I am using the adat in and out to route to my external reverb unit. And the aux input track that my reverb returns to, the output of that is routed to analog outputs 1-2.
Why when I am bouncing out is it not bouncing out my reverb even though I have routed the reverb channel to the same output as everything else and I can even hear the reverb whilst the session is bouncing out.
This is driving me mad.
I have tried routing everything to outputs 3-4 and the reverb bounces out. However I can't then hear my mix when it's bouncing out and the reverb then seems to be louder for some reason when listening back to the bounce.
I'm using a 002 rack.
Last edited by McLuckie; 03-17-2013 at 01:52 PM. Reason: Forgot to mention the interface I am using.
Old 03-16-2013, 05:33 PM
Ben Jenssen's Avatar
Default Re: Bouncing Issues
Hi. Welcome to the DUC.
Strange problem.
You shure you're selecting the right source in the bounce dialogbox?
Anyway, it ought to be easily circumvented by recording to a new track inside the session, and then exported in any format. Route every thing to a track and record it. Many people prefer it to bouncing. It has many advantages.
Old 03-16-2013, 08:24 PM
Question Re: Bouncing Issues
Hi Ben, thanks for your reply.
Yip, I'm 100% selecting the correct output in the bounce dialogue.
I've now sent all my tracks including the master to an unused stereo bus and recorded my mix to a new track. This has all my tracks including my external reverb unit.
I'm still very puzzled by this. If there are any other suggestions they're more than welcome. Or is there anyone from Avid who can look into this?
Makes no sense whatsoever as whatever you hear when bouncing out should be what's being bounced.
Thanks.
Old 03-18-2013, 11:00 AM
crizdee's Avatar
crizdee crizdee is offline
Thanks.
When youre doing the bounce to disk can you see the outboard working? the meters showing input and output etc.
Try a new session with just 2 tracks! 1. audio. 2.Aux with reverb. No master track or mix bus etc just the 2 tracks. Try bouncing this test and see what happens.
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-18-2013, 06:39 PM
zedhed's Avatar
zedhed zedhed is offline
Is the verb unit setup in the I/O menu as a Hardware Insert? You may want to look at the PT Reference Guide at 'Hardware Inserts'.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 03-19-2013, 10:06 AM
The Weed's Avatar
The Weed The Weed is offline
Do you have LLM turned on? If so, do the bounce with LLM unchecked.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-12-2013, 10:47 AM
Cheers,
Hi Weed. Thanks very much for your help. It was the Low Latency Monitoring enabled.
Much appreciated.
Jamie
Old 04-12-2013, 06:51 PM
The Weed's Avatar
Glad I could help.
Cheers,
SonoBus
[IMG] code is Off
Bouncing issues pjmusiced Windows 0 05-04-2012 12:13 AM
Bouncing Issues benplaysmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-31-2011 10:00 AM
Bouncing Issues...SERIOUSLY?!?!?! mforehand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-10-2007 12:59 PM
mp3 bouncing issues bfxp Pro Tools TDM Systems (Mac) 3 05-25-2006 02:32 AM
Digital Bouncing Issues Ang1970 General Discussion 6 04-20-2000 05:58 AM
