#21
Re: Custom pc build
anyone!!
#22
Re: Custom pc build
Hi Vin,
Shortly after installing my HD Native card in my ASUS motherboard, I remember hearing a high pitched whine whose frequency varied with different settings. In my case, it was physically coming from the card itself (or something in the case near the card - putting my ear against the rear of the case confirmed this), not through the audio path through my monitors. In searching, I found these threads: http://duc.avid.com/showthread.php?t=315202 http://duc.avid.com/showthread.php?t=315203 My experience may or may not be related to yours, since you are hearing it through your monitors. Mine was not, like I said. It was a noise physically coming from the PC case. Long story short, that episode occurred within the first weeks of my experience with HD Native while I was experimenting, optimizing, configuring, tweaking. It eventually disappeared and I have not worried about it since. Unfortunately, I cannot remember exactly what I did to make it stop. I was changing lots of things and I eventually did a complete clean reinstall of everything. I did not buy any different hardware, so whatever I did to get rid of it was a configuration issue. I do not recall exactly what I did to make it go away, but I seem to remember physically changing the PCIe slot of the HDN card and my graphics and UAD-2 cards. As part of my clean reinstall, I definitely removed all cards except the graphics card. Have you tried different slots and/or reseating the cards? Other low cost things I can think of that I was tinkering with at that time that you might want to try: Check the digilink cable If you are using S/PDIF for non PT audio, check the S/PDIF cable and the Omni settings in Hardware On the more drastic side, have you tried a complete clean reinstall of Windows and everything else? If it was the clean reinstall that got rid of my noise, I did this about 5 months after I first built my PC, so I used updated drivers for the motherboard chipset and graphics card, etc. Regarding the motherboard chipset drivers, I have an emphatic handwritten note to myself from this clean reinstall to NOT install and/or to disable Intel Managenent Engine Interface (MEI) and PCI Simple Communications Controller and to NOT accept the Windows Update offer to install this driver. I don't know if this was related. I don't have the same ASUS motherboard, but if you have any questions about settings, I can share mine with you. Sorry I can not be of more help. Good luck!
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1 |
#23
Re: Custom pc build
Hi dawgear
Thanks very much for your response, I haven't done a reinstall of windows yet. I should have my new power supply during the week and if noise still remains that will be my next move! I would really appreciate if you could show me or tell me the settings you have done in bios and just in general for pro tools. |
#24
Re: Custom pc build
I would try moving the mouse to another USB port(maybe even to the front ports) and also try a different brand of rodent
#25
Re: Custom pc build
#26
Re: Custom pc build
Hi guys
The rodent isn't the problem! Have tried without. |
#27
Re: Custom pc build
Have you had a chance to try a different power supply? I am by no means an expert, but here are my settings. Feel free to experiment. I don't know if they are necessarily the most optimal, but my system is stable and runs well with these settings. If anyone else spots something amiss, please comment. System: Pro Tools HD Native 10.3.4 HD Omni Windows 8 Pro 64 ASUS P9X79 Intel i7 3930K at 3.8 GHZ Corsair Vengeance 4x4GB CMZ16GX3M4X1866C9 Corsair TX 750 M PSU NVIDIA GeForce GT610 1024MB DDR3 3 WD Caviar Black 1TB, 2TB, 2TB Artist Control V2 w/ Eucon 2.7 ASUS P9X79 BIOS Settings Start from Optimized Defaults (Advanced Mode, press F5) Ai Tweaker X.M.P. (CPU 3800 GHz, DRAM 1866 MHz) If select OC Tuner, CPU will be 4.167 GHZ and DRAM will be 1685 MHZ Advanced CPU Config Hyperthreading: On Virtualization Technology: Disabled Enhanced Intel Speedstep Technology: Disabled Turbo: Enabled CPU C1E: Disabled CPU C3: Disabled CPU C6: Disabled CPU C7: Disabled Onboard Devices Azalia HD Audio: Enabled (for S/PDIF into HD Omni) Intel LAN Controller: Enabled (for Eucon) VIA 1394 Controller: Disabled Serial Port: Disabled Windows Tweaks ASUS chipset drivers: don't install and/or disable Intel Managenent Engine Interface (MEI) and PCI Simple Communications Controller; don't accept the Windows Update offer to install this driver. All Avid recommended optimizations; I leave Turbo mode enabled in BIOS. http://avid.force.com/pkb/articles/e...411?popup=true Acronis Scheduler 2 disabled at startup. http://duc.avid.com/showthread.php?t=317608 Windows Update: Change setting to automatically download but ask to install. Install all important and relevant (e.g. drivers, but NOT graphics!) updates. Installed everything except drivers that I already have installed (e.g. graphics card, mouse). For installing PT 10 on Windows 8: run the PT installer found in the Pro Tools Installer folder (not the Setup application outside). Use Win 7 Compatibility mode and run as administrator. Once installed, Win 7 mode should not be checked and Run As Admin may or may not be checked (I get occasional errors if unchecked , but my Logitech mouse's programmable buttons do not work if it is checked.)
Custom PC Build - Pro Tools issues | hedcase23 | Pro Tools 10 | 16 | 02-27-2013 11:49 AM |
Windows 7 Custom Build Compatibility | lbarham | Windows | 8 | 08-18-2012 07:00 PM |
Custom build CPU wont read ANYTHING MIDI | RichieRocks | MIDI | 1 | 03-21-2011 08:38 PM |
New custom build for Pro Tools 9-Help needed | viperbri | Windows | 3 | 03-08-2011 04:15 PM |
Review of my Pro Tools Computer Custom Build | VicSandersMusic | Pro Tools M-Powered (Win) | 2 | 06-21-2009 06:08 AM |
