How did I select channels?
Day 1.
If I put the cursour in a track in the edit window, the corresponding track's "Sel" switch on the D-Command illuminated. Day 2. I'd managed to change something that stopped that happening. Any ideas what it was?
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM Over 30yrs experience in pro-audio - mostly for picture. |
Re: How did I select channels?
Link track and edit selection?
D Command's SEL switches are in Focus mode.
How do you do that?
(Probably a case of RTFM, but I'm relatively new to D-Command.)
In the Global controls section there's a button where you can toggle between Sel and Focus mode.
This combined with "Track Selection follows Edit Selection" will cause the behavior you initially describe. |
If you are speaking about trying to select a track in the edit window in order to load it into the focus strip, that doesn't work for me whether I engage "Track Selection follows Edit Selection" or not.
What I do is click on the track's pan button, send or insert. That loads the track into the focus strip. If you click it twice the pop up window will go away but the track stays loaded in focus. This allows me to call up a buried fader very quickly. Otherwise I have to call the track onto the surface and then select it using the ICON select button. If anyone has a different way of doing this, I'd like to know.
Gary Gegan |
Not enough ASIO output channels available.at least 2 channels are needed. | kudca | Getting Started | 1 | 05-26-2013 04:05 PM |
How to select multiple channels and lower faders | Firechild | Pro Tools TDM Systems (Mac) | 14 | 03-07-2011 10:04 AM |
cannot select channels on 003 rack + | atkramer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-27-2011 10:04 AM |
Can you select multiple channels on D-Control? | johnnyv | ICON & C|24 | 2 | 08-24-2009 09:27 AM |
Can't select midi channels | Niljam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-08-2003 05:12 AM |
