Old 05-27-2015, 09:41 PM
Spyderrp7 Spyderrp7 is offline
Default
Ben is right, disk imaging is useful when it comes to boot partitions, but audio disks, wouldn't care less!
Old 05-28-2015, 05:52 AM
zoff zoff is offline
Default
Originally Posted by c-tone View Post
CCC is good for backing up entire disks, but if you just want to incrementally back up project files or folders (without cloning a whole drive), check out Synchronize X (Plus or Pro) by Qdea (Mac)
CCC does incremental backups.
macOS High Mojave 10.14.2
2.8 GHz Intel Core i7 MacBook Pro Retina, 16 GB RAM
Pro Tools 2018.12
Apogee Duet (Firewire)
Old 05-28-2015, 03:49 PM
c-tone c-tone is offline
Default
Right, but CCC is primarily designed to clone drives (incrementally if desired), but Synchronize X is primarily designed for synchronizing or incrementally backing up folders, which is often more useful for backing up current Pro Tools projects on a regular basis.
www.clifnorrell.com
Old 05-28-2015, 08:52 PM
audiobob's Avatar
audiobob audiobob is offline
Default
You know I got tired of using software to archive. Something would always seem to go wrong. Just never felt comfortable. Now I have a 6TB drive and when done with a session I just drag it over and delete from the audio drive. The archive drive is raid mirror which is then is backed up by Crash Plan every night. I can search that drive for anything specific and if one drive goes down then the mirror is the safety net. Pretty simple and haven't run out of space yet...Crash Plan is unlimited.
Also have another drive where Time Machine backs up the audio and system drive every hour. That's the emergency backup with (pretty) current work in case a drive happens to die unexpectedly. When that drive is full, Time Machine starts to delete the oldest files. It's 1TB and usually starts to recycle every 4 months. So far so good on everything.
Old 06-24-2015, 12:16 AM
Default Re: Backing Up Hard Disks
Hello again!
It's been a while, since my schedule was full all over and didn't have time even to check the backup programs!
I want to point here, that I'm looking for a Windows compatible program that will backup my Audio Disk to another hard disk that I have especially for backup usage.
But I want to point here that I don't like backup programs that use image files. The reason for that is because sometimes I want to quickly go to the backup disk and pick up some files that are there, and don't want to wait for the whole image to be restored in case something goes bad.
So by saying that, I checked the programs you adviced me to check.
1. Acronis True Image 2015: User "The Weed" adviced me to stay away from this last version so I dind't even checked it.
2. Macrium seems to only backup to image files.
3. Image for Windows seems to only backup to image files only too.
4. AOMEI Backupper software also backups only to image file.
Isn't there a program that will just copy files and folders, with no compression, no image files, so I can make incremental backups?? I don't want to use image files.
Old 06-24-2015, 08:17 AM
The Weed's Avatar
The Weed The Weed is online now
Acronis and Macrium both allow you to mount an image as a virtual drive, search it and copy out anything you like. I did it yesterday as I had modified a file, closed the program and then realized I had deleted some information from the file I wanted to keep. I mounted a virtual drive of the image, copied off the old file, opened it and then copied the information I needed back into the new file.
Both also allow you to clone a drive if that's what you want to do. (Please remember that cloning will erase all previous data on a disk/partition.)
Macrium does allow File & Folder Backup and incremental File & Folder backup. Both Acronis and Macrium allow incremental image backup once a full image has been done.
I and others here use images because with images you can keep various images from points in time, like the initial install of Windows, Windows with just Pro Tools, or an image just before you install a new program allowing you to go back to a working system if something goes south with the new program or another point in time.
I keep a number of images archived and a 2 day image in rotation. For example, I have full images from Monday and Tuesday of my OS drive on my Work computer. Tonight, I'll delete Monday's and make a new image for Wednesday at end-of-day. As I sleep, the image will be made, verified and the computer turned off.
Cheers,
Demos: brucehayward dot com
Source-Connect: brucehayward
Best way to organise Hard Disks? badagent1 Storage Subsystems 2 05-07-2009 02:55 AM
Backing up to DVD-RW disks Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-01-2007 05:16 PM
Does PTLE Run better with 2 Hard Disks? JasonGough 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-21-2005 10:42 AM
Hard disks. Help me please... poroto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-10-2004 11:08 AM
DMA on 'old' hard disks Flosskkii Digidesign Hardware & Software 3 03-25-2001 03:48 PM
