Old 05-08-2009, 02:37 PM
koka koka is offline
Default short vs long delay compensation sonic
Hi , does anybody hear the difference between same project in short or in long
delay compensation option in HD.
We think that project with short delay copesation sounds better.
What do you think?
Old 05-08-2009, 03:05 PM
elicious elicious is offline
Default Re: short vs long delay compensation sonic
do a null test.
e
ihatetyping
Old 05-08-2009, 05:43 PM
Eric Lambert's Avatar
Hmmm... I don't think there should be any sonic improvement, short vs. long. If anything, it will be noticeable in the timing of the track, tighter or looser.
Old 05-08-2009, 06:32 PM
KingFish KingFish is offline
Well as long as none of the track "Delay Dialog's" are reporting "RED" by design, there SHOULDN'T be a difference at all.
the Long Delay setting, is for mixes, where you're using several plugins per track, which combined delay, exceeds the maximum (1023) Samples allowed in the "Short" setting.
Switching to "Long" allows the Mix Engine to compensate up to 4095 samples.
The only way you'd "Hear a difference", is if your session had tracks incurring a delay beyond 1023 samples, and the Mix engine Delay Compensation setting was on "Short"
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Click, D-verb, Extra Long Delay II, Short Delay II are missing in PT10 UPGRADE ruxandra Windows 6 06-20-2012 05:29 PM
Where Did Extra Long and Short Delay II Go? Trailerman Pro Tools 10 6 01-18-2012 01:57 AM
ADC, Short delay or Long dalay?? bobo mark Pro Tools TDM Systems (Mac) 1 02-24-2006 06:01 PM
PT quits when selecting long delay compensation oddeodude2012 Pro Tools TDM Systems (Mac) 2 03-23-2005 08:47 AM
Strange Behavior on Long Delay Compensation rnt_u_listnng Pro Tools TDM Systems (Mac) 4 08-18-2004 08:41 PM
