Old 12-06-2006, 11:15 AM
Humongous Humongous is offline
Default No Bypass of mic pres on the Mbox2???????
If you view the thread I started yesterday 52 views and no replies please advise, you can see that no one as of yet can tell me correctly how to bypass the mic pres on the mbox 2. My simple request is how to bypass the mic pres on the mbox 2 so I can use an outboard preamp. Gain structure wise it seemed like I was taking a pre into a pre. I'm still convinced that is the case. I was told (wrongly) by Digidesign to push the DI button and plug into the TRS line input on the back and this would disengage the mic pre on the mbox 2. After I told them this doesn't work and cuts the signal I haven't heard back from them. When I repeatedly asked the question "does plugging in the trs inputs disengage the mic pre automatically" I was told by Kman that it does and he suggested a couple of tests to try to verify his theory. I did the tests and he was wrong, it DOES NOT automatically change to a line amp and bypass the pres on the mbox 2 when I plug it in to the trs input as he assured me that it did. Can anyone tell me what's going on here?
Jeff Powell
Memphis USA
How to bypass the mic pres and the AD converters - 003 GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-06-2007 10:16 AM
How do I bypass 001 mic pres jetboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-19-2004 11:33 PM
Can you bypass the 4 pres on the 002R? spicyitaliano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-31-2003 11:41 AM
Can the Mini Me's Pres be bypass and only use the converter Jason Calleiro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-03-2003 11:53 PM
Bypass digi001 mic pres thru XLR inputs? trew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-02-2002 07:25 PM
