Hum from Clavia Ddrum4 module
Using electric guitar first time since the time having a LCD monitor I expected to have no more radiation to the pickups of the guitar.-
But it shows that the drum brain radiates and even very strongly ( appears like more noise than from usual monitors ). Clavia responded: "The ddrum4 brain shouldn't radiate that much. Could it be that your other equipment is very sensitive?" I would like to find out if my guitar as such could be indeed too sensitive or if I got a bad module ... Although there seem not to be too many Ddrum users it would be nice to hear from others experience if any should happen to see this post. Thanks! Lalaman |
Re: Hum from Clavia Ddrum4 module
If you are saying that you think the Ddrum is causing guitar hum due to electro magnetic interference, it does seem unlikely to me. I record guitar tracks sitting about 4 feet from a Ddrum 3 brain. Since I got rid of my CRT monitor, I have as little hum as one can reasonably expect from guitar pickups. It's been great.
If you find that the hum goes away when you shut the Ddrum on and off, maybe it's related to a grounding issue with the circuit the Ddrum is plugged into (??) or something like that. Tom |
Yup, it definitly comes from the Ddrum unit. The brain is plugged to another plug than PC/Digi but they are hooked all to the same wall socket, so I guess it means the same circuit yet.
-I´ll try out then if it is better when plugged into the same extension cord. ( If I find out which plug belongs to which ... got more cables here meanwhile than General Electric [img]images/icons/grin.gif[/img] ) Thanks for confirming that the brain mustn´t be the bad boy! Lalaman |
I have a Ddrum 4 SE System 1 set up and haven't had any problems with hum...Maybe you could record the audio of the Ddrum to Protools and then shut the Ddrum module off...If you still get the hum while recording then it positively isn't coming from Ddrum...
Nehalem 2.66 quad core, 32 Gig RAM , 640GB , 2TB Seagate, OSx10.8.5, PTHD10.3.8, HD3 Accel, MidiIO, 192, 96i, Pre |
Yes that is always an option. I didn´t do it yet, cause I am always hesitating with audio because unconsciously fearing to corrupt session with too much of audio files and also because of an old habit from those days were you had to be stingy with HD storage. But as I checked out connection of the unit ( it is hooked together with PC and Digi ) and since XP ( received last necessary part to work with midi & audio on it yesterday and it is working absolutely great ) with 180 gig ... You are right I will convert the midi drum tracks. I just was wondering anyway about the brain ( as it is much to quiet through headphones while playing and e.g. the kick pad hardly to be heard, while as played back it tends to distort. Then if I lower inputs in PT it sounds ok again until minutes later where it distorts again. Also cymbals can´t be muted by hand and other phenomenons like that, you know. [img]images/icons/confused.gif[/img] ) if it maybe was not in the right condition the way it is. Greetings Lalaman |
On Ddrum, Are you using version 1.4? You can get a chip for around $100 that takes it to version 1.5 and the big deal is it boosts the main output 6db....I can tell a difference at the main outputs but haven't tried the headphones since the upgrade but your absolutely right that the headphones are hard to hear...The way around that is to patch the module into a mixer and use the mixer headphone out to monitor through headphones...I get plenty of volume that way...The best way to mute the cymbals would be to use the multiple audio outputs on the module...Just put the cymbals out different outputs of the module and then they can be muted.....
Or do you mean when you grab the cymbal pad it won't mute?....If you feel it's acting buggy then maybe you should reinitialize the unit...Or just reset the factory settings...You'll lose your personal settings you put into it but at least it could possibly clear up the bugs...
Hey Moon,
what I have is ver.1.5. I do route it through PT in order to hear it better in phones. But it is hard to believe that signal is supposed to be so quite from the units phone outs. Clavia says that there has to be reserve for headroom in regard of hi-hat and cymbs, but a signal so low that you can´t get it over the sticks noise through half closed headphones? Hard to believe as regular I thought. Yes, I meant muting by grabbing. That didn´t work here from the beginning. But still, I´m gonna check the manual once again in case there is anything left to be considered. Thanx! Lalaman Would you have an idea why bass kick appears recorded to loud ( in midi ) and how came that it varies ( sometimes distorting, sometimes not )? [img]images/icons/confused.gif[/img] |
No, I meant - and that is what is so curious about it - varying while the same midi notes are played back through the module ( send from within PT ).
Sensitivity is not raised to max by far, although a bit above of what I would adjust it to when recording for final audio track, but yet in order to be able to hear the kick among the other pads while drumming it is usually set around "1 o´clock". I´ll check about trigger types / cymbals! Thanks! Lalaman |
Clavia Nord Lead | Digi_User. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-07-2009 01:22 PM |
ddrum4 Hangs During MIDI Playback in PT 7.1 | 510man | MIDI | 1 | 12-31-2006 11:56 AM |
Anyone using the Clavia Ddrum4 Brain? | Swaphappy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-07-2004 07:13 PM |
Clavia | J. Guerrero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-31-2002 12:06 AM |
001 and Clavia Micro Modular | petter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-25-2001 04:05 AM |
