will eleven rack work with pro tools 11
hi im looking at an eleven rack on ebay and i need to know weather it will have any compatability issues, or will it work fine? are there any different versions of the eleven rack? should i just go ahead and buy it? any help would be great thanks
max |
Re: will eleven rack work with pro tools 11
Eleven rack works great with Pro Tools 11
There is only one version of the 11 rack however there is a firmware update called the expansion pack that you definitely want to have The auction should specify
thanks alot for your feed back, so this should be ok because it says expansion pack pre loaded? http://www.ebay.com/itm/Avid-Eleven-...item1c36c65acd
The eleven rack works fine with pro tools 10 and 11 for the price it's a fantastic bargain . I bought one from this guy , really helpful great customer service
His sellers name is gsharpmusic on ebay . Message him ask any questions Excellent helpful guy. Enjoy it best wishes Kimball |
As mentioned, the 11R will work with Pro Tools 11, you can checkout my YouTube channel to see it working with PT11 if you wish.
But, you need to know that at this time, the 11R on-screen editor is not available in PT11, for that you will need to use the co-install of PT10 The on-screen editor is also available in PT LE8.0.1 and higher and PT9. If you already have PT11 then this is a great deal, if you would like to get Pro Tools 11, check out the new Eleven Rack on B&H Audio, last I checked it was $618 and included PT11. Good Luck.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
cool, hey thanks alot guys
That is a problem with the new Imacs in general, with various brands of audio interfaces. It's not Avid's problem at all. It's 100% Apple's problem. There are various threads on forums about this.
How to connect other hardware to Eleven Rack and make it work in Pro Tools 11 | TENM | Eleven Rack | 0 | 03-11-2014 05:55 AM |
Eleven Rack Does not work with USB 3!! | braytunes | Eleven Rack | 7 | 12-04-2013 04:28 PM |
will this work on eleven rack? | cowboystewart | Eleven Rack | 9 | 11-03-2012 11:27 AM |
Eleven Rack Pro Tools 8 disc doesn't work | spasm | Eleven Rack | 4 | 01-29-2012 09:01 AM |
Pro Tools 8.0.1: install disc doesn't work (Eleven Rack) | Mister_Riff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-21-2011 08:20 AM |
