Recording shuttle sound
Hi
Is there any way of recording within pro tools the effect of varispeeding / shuttling the timeline. I hold ctrl and Alt and use the mouse, but how can I record this variable affect. Peter |
Re: Recording shuttle sound
You can tell that you are a former Audiofile user.
As far as I know, it's not possible to do this. I usually do it the old fashioned way and record to a DAT machine and then play that back into Protools. It's the only use my DAT machine gets these days. If I were smart, I'd record into my PC that I use for email, which sits just to my right, and then just copy the newly created file over the network. -Richard
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5 www.TakomaMedia.com |
I record srubbing effects to either my hardware sampler or a second system when available.
You could try using TapeIt if you have the VST to RTAS converter by FXpansion , or try OpD2d , though that may not work as I don't think it would be able to access the output of DAE, so you might have to physically patch your hardware outputs into your motherboard sound card. You Could also try Audio Hijack for Mac. Hope that helps. |
Hi Peter and as a side note many thanks for passing on my details to Big Bang, they now have my logic 3 and audiofile and I am concentrating on PT.
Over 30 years in Broadcast Film and TV: www.HDProductionSolutions.com |
Do you own an extra computer, or know anyone with a computer that has any type of music software that shuttles and scrubs? If you do.... use that as your source sound and record it into PT....simple....
i believe i used to be able to record protools shuttle transport sounds into Serato Scratch.
Bouncing out and back in is the only way Ive been able to get it done, but I was asking if it can be done internally. Seems not, at least not within PT.
Peter |
try this plug
http://www.digidesign.com/index.cfm?...00&itemid=4991 records everything out the 2mix into your ram, and then you can drop it back into protools
Dave Kaduk Particle Audio |
do you know for sure that snaptricity records shuttling/varispeed effects? It would seem to me like it just records things that can be recorded via the record button... They don't specifically mention on the site either way that I could find...
At least that's my read of the thing. Looks cool either way. |
Recording a sound live and altering it, or altering it before recording ? technique | Matt Darcy | General Discussion | 4 | 04-08-2009 08:32 PM |
recording in shuttle mode | nate9 | ICON & C|24 | 1 | 03-24-2009 11:04 PM |
Recording sound from shuttle wheel | koe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-10-2007 07:16 PM |
Recording volume low, Mbox not in "sound recording" | carlg1212 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-19-2007 02:32 PM |
Sound on Sound article about recording with PT LE | yavuzj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-16-2006 10:46 AM |
