Old 10-04-2016, 08:21 PM
sloanlogic sloanlogic is offline
Default List of bugs in PT 12.6 - please contribute
Can we put the list of bugs here please?
Old 10-04-2016, 11:04 PM
Stereo Missile Stereo Missile is offline
Default Re: List of bugs in PT 12.6 - please contribute
I've had multiple beachball hangs when holding down option and trying to resize track heights in the edit window. Anyone else experiencing this?
*EDIT* I seem to have narrowed this down to the D16 Punchbox VI plugin. It is fine once I commit the track with that plugin.
PT12.6
OS10.10.5 Yosemite
HDX 1
S6 M40
Mac Pro 6,1
Steve Peach
Stereo Missile Recordings
Creative Director - Red Note Visionary Sounds: http://rednote.com.au
Label: http://www.stereomissile.com/
Music Production / Mixing: http://www.stereomissile.com/musicproducer/
Mastering: http://www.stereomissile.com/mastering/
Last edited by Stereo Missile; 10-04-2016 at 11:26 PM. Reason: Updated information
Old 10-04-2016, 11:22 PM
surstromming surstromming is offline
When recording audio the recorded audio is late in the timeline by the same amount of the set buffer size.
So if the buffer size is 128, the recorded audio is 128 samples late, and if the buffer size is 512 recorded audio is 512 samples late.
Happens in non-HD PT.
I reverted to PT 12.5.1 and then the recorded audio is dead on the beat.
Regardless of set buffer size.
To test, record a click from click track to a audio track with a mic in front of monitor and then look at the waveform.
I´ve created a case about this and waiting reply.
Update:
This is being looked at now.
Update 2:
This has now been reproduced by Avid support and recognised as a bug related to when the "ignore errors during playback/record" checkbox is checked.
If it is not checked all is fine.
When it is checked all recorded audio is late.
For me I also need to set the buffer size to 256 or higher, otherwise the problem won't go away after checking and unchecking the "ignore errors..."
So let´s now hope for a fix.
Best regards
Markus
Windows 10
Intel core i7 4790k, 16Gb ram
MacBook Pro Retina 13" late 2013 OSX 10.12
Intel Core i5 2,4 GHz 8GB
Pro Tools 2018.4
Eleven Rack + Expansion pack
RME Fireface UCX
Last edited by surstromming; 10-22-2016 at 06:59 AM. Reason: Spelling and uppdate.
Old 10-05-2016, 01:47 AM
Mitchel Mitchel is offline
GUI bug. Whilst scrolling up down left and right during playback, all sub counters and transport counters FREEZE!! Been happening since PT12. iMac 5k. PT HD Native.
Old 10-05-2016, 03:29 AM
laki laki is offline
When trying to use the Clip Effects, I can't use the top two frequencies of the EQ until I edit the clip.
See Video Here
Mac Pro 2013 OSX Yosemite. HDX1
Old 10-05-2016, 05:34 AM
DJ Hellfire DJ Hellfire is offline
Yellow fade adjustment line looks and is positioned differently than the actual fade that is applied to the clip.
www.HellfireBeats.com
Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61, Focal Alpha 80, UAD 2 Apollo Quad, UAD 2 Satellite Quad, UAD 2 Octo PCIe, Neve R6 "Lunch Box", Neve Portico 511, Neve Portico 551, Neumann TLM49
Pro Tools 2018.10
Mac Pro 4,1 (5,1 upgrade), Early-2009, 3.46GHz Nehalem 12-Core, 32GB RAM - OS 10.12.6
13" MacBook Pro, Late-2011, 2.4GHz Dual Core i5, 16GB RAM - OS 10.12.6
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - OS 10.12.6
Old 10-05-2016, 08:17 AM
del cosmos del cosmos is offline
Midi Latency Problem welcome back in 12.6
http://duc.avid.com/showthread.php?t=384719
Old 10-05-2016, 08:28 AM
Arionas Arionas is offline
Many of the above, plus that undo doesn't work under midi editor.
Old 10-05-2016, 12:20 PM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
You might stand a better chance of getting these fixed by reporting them to Ideascale.
http://protools.ideascale.com/
I will choose,
Freewill
http://jimdiazaudio.com/
Old 10-05-2016, 12:34 PM
daeron80 daeron80 is offline
Good heavens. One step forward, two steps back. Sticking with 12.4 and following this thread to see how bad it gets.
David J. Finnamore
Nyquist was right.
PT 2019.6 Ultimate | Omni | macOS Sierra
PT 2019.6 | Saffire Pro 40 | Win10
(Official?) AAX BUGs list Peterjk AAX Plug-ins 13 08-04-2012 09:04 PM
More PT8 'Configuration List' bugs... Mixmaster Nate Pro Tools TDM Systems (Mac) 6 06-01-2010 07:54 PM
6.9.2 list of bugs Mike Czech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-15-2005 07:04 PM
please contribute Vertual instruments KoblahGbeho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-18-2002 05:46 AM
A list of those annoying bugs for DIGI audio junkie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 09-04-2002 04:13 AM
