Control key and vertical movement
I've been having issues for quite some time..
supposedly holding the control key will restrict clips moving left and right. - allowing vertical movement only.. This isnt always true - and sometimes its true for a little bit.. I am reorganising sessions supplied on OMF ( its my job! ) and often when holdin the cntrl key the clips will slip in time as well as moving tracks.. sometimes the control key will constrain horizontal movement for a few tracks and then even tho I havent let go they wil suddenly be free to slide around the time line... anyone else experience this?
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive Focusrite Saffire PRO 40 Ultimate 2022 10 / HD Avid MC Mix / MC Control |
Re: Control key and vertical movement
That might be a matter of the order of selecting a clip and when to press Ctrl.
Select clip , press Ctrl , drag (correct) Press Ctrl , select clip , drag (wrong). Maybe you could do this, for the initial placing of the OMF files to their correct tracks in your template : select all clips on all tracks - Time Lock (Menu : Clip - Time Lock/Unlock).
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Hold ctrl + clic on a clip (with the grab tool) send the clip (start point boundary) to the Edit selection. (there is other shortcuts : - ctrl+shift+clic key combos, to send clip (sync point) to the Edit selection. - ctrl+cmd+clic key combos, to send clip (end point boundary) to the Edit selection.) Most of time, people have linked the Playhead and Edit Selection, and their selection is at the same time position as the clip they want to move vertically BEFORE ctrl+clicking, so it works as "constrain vertical movement". If you unlink Edit and Play selection OR if you don't select your clip with the grabber tool BEFORE ctrl+clicking, you won't have the "constrain vertical move" behavior.
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD) MacMini (Core i7 Quad@2,3GHz RAM16GB SSD) PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP) PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP) PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD) PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD) RME UFX (USB2 with MM and Firewire with MBP) + Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1 Last edited by demodigi; 10-02-2015 at 12:29 AM. |
thats interesting! the link edit and playhead - have to try get my head around it
I notice that with the option modifier is sometimes like that too- I wonder if I am a bit quick on the wacom sometimes.. ie the modifier press - then the 'mouse' click too soon? actually the first thing I noticed on firing up my mac mini ( after retiring the mac pro ) was Protools seemed just a little bit 'laggy'
(Remark : but please do NOT report this as a bug, it is like this for a long time -> PT6 ? PT7 ?, at least since we can link/unlink Edit and Playhead)
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD) MacMini (Core i7 Quad@2,3GHz RAM16GB SSD) PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP) PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP) PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD) PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD) RME UFX (USB2 with MM and Firewire with MBP) + Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1 Last edited by demodigi; 10-02-2015 at 03:32 AM. |
The unintentional pressing of Ctrl prior selecting a clip can really easily be avoided by time-locking the clips, because no modifier is needed to constrain the movement to vertical.
aha! OK I finally see the light!
good call.. import OMF to template.. lock all clips - drag into correct tracks.. unlock all- edit to hell.
Reproducable Crash PT9 on Win 7 - Vertical Scroll Control | cwp | Pro Tools 9 | 5 | 09-04-2011 06:47 PM |
Where is the Disable Fader Movement During Playback feature for Control 24? | The Missile Silo | Pro Tools TDM Systems (Mac) | 5 | 12-01-2010 09:22 AM |
Control 24 - fader mm movement | IntelDoc | ICON & C|24 | 8 | 07-02-2009 10:06 AM |
cursor movement? | johnwayne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-03-2007 01:46 PM |
Redrum Question ..strange control movement | bryanbassett | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-01-2005 09:44 AM |
