Old 02-28-2024, 11:14 AM
freakhouse freakhouse is offline
Default plugins moving
On PT now if I drag and copy a plugin on top of another tracks plugin it shifts everything down a slot. In other words, it inserts instead of replaces. Is there a way I can disable that when I want to replace. I'm guessing by adding a modifier key.
Old 02-28-2024, 12:22 PM
Default Re: plugins moving
Keep dragging. If you drag directly over the top of an existing plugin, you will get a yellow box around that plugin, indicating it will be replaced. If you drag between 2 inserts, you will get a thick yellow line between inserts, indicating that the plugins will be re-ordered.
Scott Gatteño
Problem moving plugins back into Avid Plugins Folder briaboy Pro Tools 3 07-28-2023 07:45 AM
Moving Plugins From PT 8 to PT 11 tangoportland Pro Tools 11 10 05-25-2015 03:19 PM
Moving from Mac to PC because of plugins? garnoil Pro Tools TDM Systems (Mac) 11 05-28-2008 01:28 PM
Moving Plugins loudestnoise Pro Tools TDM Systems (Mac) 6 07-10-2007 02:57 PM
Moving plugins... GW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-22-2005 11:49 PM
