Old 02-01-2024, 01:36 PM
musiclee musiclee is offline
Default How to change an AUX from Mono to Stereo AFTER it has been created
so can you do it?
can you change an AUX or Audio track from Mono to Stereo after its been created?
you can in Studio One, easily by clicking on track icon to change
If not, why not?
Old 02-01-2024, 02:04 PM
Default Re: How to change an AUX from Mono to Stereo AFTER it has been created
Right-click on the track name and scroll down to Change Track Width then select Stereo. You may need to assign a new bus, if the previous input bus was mono. Any plugins that have stereo versions should automatically change to stereo instances.
Scott Gatteño
Old 02-01-2024, 02:14 PM
thanks Scott, on AUX, all good, and yes, i have to reassign a buss, as it goes back to default analog 1, even though there is a stereo version of this BUS, when i do it manually
and seems i can't do this with Audio tracks, (mono). as change track width is "greyed" out, not sure why?
perhaps because there are mono audio regions on track?
and why they call it. "change track width". thuat makes it seem like you want to change the gorizontal size of track,
Old 02-01-2024, 02:19 PM
Yeah, you can't change the track width on an audio track when there's any clips on the track or on any playlists associated with the track.
The verbiage is referring to "channel width".
Scott Gatteño
Old 02-01-2024, 02:25 PM
your time in helping is much appreciated,
i just wish i didn't have to reassign. the BUSS on the AUX channel.
and yes, i did confirm. that the mono insert FX, do change to stereo which is nice,
Old 02-01-2024, 02:38 PM
but there is a bug, with this,
IF you have your AUX colored, as you can do in 2023.12, and change from monot to srtereo, you will LOSE your color on that AUX, and even if you goto I/O in settings, and change to same color or any color, the AUX name will ALWAYS stay gray,
Avid, please look into it.
not a huge bug, but a bug
Old 02-01-2024, 02:42 PM
when i say COLOR of AUX, i do not mean the channel strip color, i mean, just the color. of small OUTPUT box with name
Change recorded mono synth track to stereo Red Raven Audio Pro Tools 1 09-26-2023 12:26 PM
Can I change Multi-Mono Template to Stereo? Mixmaster Rick Pro Tools 2020 2 04-19-2022 09:33 PM
Bussing a Stereo Track to Mono Aux: Summing change from 2018.3 to 2019.5 laki Pro Tools 2019 10 06-27-2019 03:14 AM
Change a track from mono to stereo in PT12 jamestr12 Pro Tools 12 11 04-14-2017 05:13 PM
Best way to change dual-mono to stereo tracks ??? vudoo Pro Tools TDM Systems (Mac) 1 02-21-2005 06:35 PM
