Dropbox – Mac OS X – Alias of 'Recording Files' folder
Hi all,
TLDR; Will Pro Tools 11 run session files from an alias of 'Recording files' folder? I want my session files to be automatically backed-up in DropBox. I've searched for an answer to this, but haven't seen anything apart from going through each session and clicking 'save copy in' one's Dropbox folder. As DropBox is saved locally, but backed up in the cloud, it should be no problem to run sessions from your local 'Dropbox' folder. As such, I want to move my 'Recording files' folder to DropBox and create an alias of 'Recording files' to leave in the original folder [/Macintosh/Pro Tools/]. Obviously, I'd ensure the alias had the exact same name and location of the original folder. Is there any reason this shouldn't work? That is, will Pro Tools be happy to follow an alias folder? Many thanks, z Additional explanation: This approach will ensure that my recording files will always be updated each time I've made changes to a session. This is an automated solution to what would otherwise be a tedious drag-n-drop post every change to a session. |
Re: Dropbox – Mac OS X – Alias of 'Recording Files' folder
You may want a hard link, as described in What Are Aliases, Symbolic Links, and Hard Links in Mac OS X?.
If you have Pro Tools | HD, you should have no problem running the session from a Dropbox folder, as you would have access to the Disk Cache (Setup-->Playback Engine). Set the Disk Cache high enough so that it caches all of the audio in your clip list and you should be ok.
There used to be a Briefcase folder on Windows that supposedly does what the OP wants, I never tried it but maybe there's a similar thing on Mac.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Running PT11 Sessions from Dropbox folder | pgripp | Pro Tools 11 | 8 | 01-29-2016 10:24 PM |
Problems Sharing files thru dropbox | Gabriel810 | Pro Tools 12 | 1 | 01-22-2016 03:50 PM |
To anti-alias or not to anit-alias? | peytontodd | Windows | 1 | 07-10-2014 10:40 AM |
Plug-Ins Alias folder points to wrong folder??? | nod25 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-26-2009 03:43 PM |
SFX files aren't loading to Audio Files folder | sidereal-studios | Post - Surround - Video | 5 | 06-06-2007 01:53 AM |
