Smart Code Pro - Files \'Pumping\' On PCs
I've posted this question to UA as well, but maybe someone here has the answer. I'm using SCP Dolby to software encode DVD menu audio.
Apparently, the house DVD authorer complains of a 'pumping' upon playback of an authored dvd on pc's and macs alike. The strange thing is that there isn't any pumping if the dvd is played back on Consumer Playback Decks. Here are my settings when encoding: Audio coding mode: L/R Bitstream Mode: Complete Main Dialog Norm: -27 db Dynamic Range Compression: None Input Filtering: DC Highpass Filter ON Bandwith Lowpass Filter ON |
Re: Smart Code Pro - Files \'Pumping\' On PCs
lefty-
most likely what is happening is that you have a fairly loud source material... this is probably causing the AC3 compression codec to kick in (Dont' confuse this with the AGC that's always on in AC3..). The reason that the consumer deck isn't exhibiting this is most likely that the Decoder is set to ignore the Dolby Meta-data (The Dia Norm, down mixing, room size etc...) Try to see if the receiver has this feature and if so, turn it off. If the pumping goes away, then there's your issue. to Fix this, you have to encode your AC3 with the proper Dia norm setting (If your program is hot, then I guarantee that it's hotter than -27dB). -Todd A. |
I've seen this in a DVD I bought last year. It would pump in the Mac but never on a standalone player. I thought that I had a bad pressing (or more likely that they realised they had an error on their hands and re-mastered it) so I bought another one, same thing. Annoying!
If the "smart tool" was really smart... <tongue in cheek> | KingTor | Post - Surround - Video | 10 | 03-02-2010 09:47 AM |
Pumping in Dynamics III | yin7yang64 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-25-2007 07:26 AM |
concerning time code on AIFF files for AC3 | Mlanders | Pro Tools TDM Systems (Mac) | 1 | 09-01-2005 11:52 AM |
pumping sound | lonestarparis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-01-2004 12:42 PM |
Dithering question about Smart Code PRO Dolby Encoder | poldo | Post - Surround - Video | 10 | 08-20-2003 03:35 AM |
