basic input level for vocals on a mic pre
i wanted to know if anyone could give a little advice on a basic input level for vocals using the compressor on any mic pre. i have a neumann u87, avalon 737, protools 10, and a mbox pro 3. i understand compression inside of protools, but outside is kinda different.
Re: basic input level for vocals on a mic pre
But, I've been told by Sound Engrs & Pre Amp Manufactures to start with Output at Max. Set Input level low & increase til you achieve the best sound & level. You can fine tune Ouptut level but shouldn't need too much. Larsongs |
Nice!!
Curious - what's the thought process on this? Seems like you could be increasing noise by starting with the output maxed. Been a few years since I've used an Avalon, but I generally start with the output (and eqs) at 0, get a good level into Pro Tools by adjusting the gain, then add compression/eq using the output gain to compensate for level changes. By setting the output maxed to start with, you have nowhere to go but down so that if you need more level, you have to adjust the gain which will affect the compression, if you're using any. Hope that makes sense!
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
ok makes sense, only problem im running into is compression. seems like my mic pre squashes the hell out of vocals if added before going into protools. whats a good signal chain far as ratio, threshold, attack and release. i dont know if i should do a fast attack, slow release, or the opposite.
I had the same curiosity as you. I called the Owner of Vintech. The recommendation i'm telling you is what he told me. I called some Sound Pro's at Sound Pure. They said the same thing. Thanks, Larsongs |
Comp going into PT should be 1:2 ratio at most..... Threshold depends on where your levels are Part of the reason the 1176 is beloved is it has a quick attack time And yes there are really very few rules, if it's too much compression raise the threshold and reduce the ratio And if you still can't figure it out, I'll pm you my address and you can ship that stuff to me !!!
Yes, it really depends on how it sounds in the song. I tend to use light compression to Pro Tools as you can always add more compression, but it's very difficult to remove it.
HDX Input Monitoring level changes to previous fader level when disengaged | ArtyMorty | Pro Tools 12 | 4 | 09-29-2015 09:21 AM |
input monitoring level and record level different | Jason1 | macOS | 8 | 12-07-2014 10:06 AM |
Compressor 3 output level=input level?? | JonesH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-16-2009 05:59 PM |
Want a good basic filter for vocals or whatever | 6969 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-04-2006 11:26 PM |
Stereo buss level low relative to input level | twodb | Pro Tools TDM Systems (Mac) | 4 | 01-31-2006 04:49 PM |
