Lost presets
Anyone else switched on to find all their presets lost (i.e. as if reset back to factory defaults)? I found a post from Benoni confirming this had happened to him.
I've just started to use my ER and had saved only a few presets ... now wondering if this is just a quirk of ER and how common it is?! Thanks! |
Re: Lost presets
Weird ... switched off/on again and they're back! :)
Re: Lost presets
Well thats good. And Lucky. When it happened to me, I completely lost everything and they did not come back so I had to save about 100 rigs 1 by 1 in the order I had them in before. I didn't actually lose any rigs since I had them saved to the PC, I just didnt have a full dump of the way I had them set up. Once you get a few rigs in the place you want them, do a full dump so in case something happens you can go right back. Whenever I make presets, like I am currently doing now, I will save a full dump at the end of every day. Don't fear the Dump
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Re: Lost presets
Cheers Benoni.
FWIW, I went over 'before' and 'after' in an effort to diagnose ... think I may have switched off 'mid-edit' (modified patch which I hadn't yet saved). When I switched on with missing presets, my ER also wasn't showing on my Mac - I understand this is not uncommon. It's as if the ER didn't 'boot up' properly/completely ... evidently the user presets were still there and in a different location to the factory presets. I guess reporting of this on the forum may not be prevalent if, for some at least, this has been resolved by switching off/on again? Good to see that you've only encountered this once though! Thanks for the advice - will 'dump' to Mac once my rigs are a bit more refined! |
Re: Lost presets
I definitely don't fear the Dump, that's why I don't save it till the end of every day...indeed I find morning is best
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Re: Lost presets
Are you pulling his chain
Re: Lost presets
Old thread, but thought I should share that the same just happened to me.
I'd spent many hours renaming and tweaking presets then as I switched on my 11R tonight all the presets were showing as factory loaded presets. I started to freak out as I'd done a number of hours of tracking on a project with a tone I was happy with. Edited a preset, saved it, powered down and powered back on, after which all of my presets appeared again, except for the one I had modified in this previous strange state. |
Plugins lost all of their presets | galtesler | Virtual Instruments | 3 | 06-03-2011 01:09 AM |
Lost All Plug-In Presets...Help! | sabreplayre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-22-2007 07:28 PM |
lost plug in presets. | ThomasPMusic | Pro Tools TDM Systems (Mac) | 1 | 08-17-2007 06:00 PM |
lost my presets | surely | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-03-2005 01:41 PM |
Lost presets | Stig Eliassen | Pro Tools TDM Systems (Mac) | 1 | 04-06-2005 02:38 PM |
