Old 06-01-2011, 04:54 PM
-JK- -JK- is offline
Default Pro Tools won't recognize my Apogee interface
Hi there,
I finally managed to get my new PC working and got to finish my setup today by installing an X-HD card into my Rosetta 800. Unfortunately my HD Core card doesn't want to accept it as its interface as I get the error message "Unable to find audio interface attached to the first HD card" after starting it up. The funny thing is that it does see a 96/192 interface in DigiTest. Does anyone have any idea what the problem could be?
Regards, JK
Old 06-02-2011, 01:59 PM
doubtful guest doubtful guest is offline
Default Re: Pro Tools won't recognize my Apogee interface
check to see if the firmware on the rosetta is up to date.
i've found apogee to be very good for support.(and avid doesn't like to give support 3rd party interfaces) I'd call or email apogee, they should get back to you right away.
Old 06-02-2011, 11:22 PM
Thanks for your reply! I tried to update the firmware and I think everything worked fine (except that it didn't switch from the red to the green LED after completion), but I don't know of a way to check this. Do you? I will try to contact Apogee or an Apogee partner as well.
Old 06-11-2011, 08:18 AM
OK, so it seems that there's no support for X-HD cards in Pro Tools 9 anymore as I connected a 96 I/O which works just fine. Would be great if Avid could reply and explain if this is an error or by design! Thanks in advance!
Old 06-11-2011, 09:34 AM
Willard Willard is offline
I had strange problems when I initially installed 9. I wrote the following to Apogee (quick replies, very helpful).
"Only been up and working on v9 for a few weeks, moved from v7.4 (ppc).
Yesterday installed 9.02 over 9.01. Restarted both rigs and kept working. Today I open a session on the Magma/PCIx/Apogee rig, and it won't recognize the hardware. Trashed prefs, repaired permissions, no joy.
I keep a g5 2.3dp ppc rig intact for recalling, and PT booted fine in 7.4 with the hardware configuration (I bought an extra Magma PCIe card, so I could just move a cable and iLok between rigs to recall). Swapped the PCIe cards between machines, still no joy, so it was obviously the software. Looks like I have the latest version of the X-HD (Apogee card) firmware 2.07. Reinstalled PT 9 and the 9.02 upgrade and I'm back in shape. Or so I thought. Restarted one more time, and I'm back to no hardware. Reinstalled v9.0 and still have the same problem."
After this i did a hardware reset (sample button on power up). I believe I have the latest firmware. But it does not say 192 Digital i/o in Pro Tools. Should I just reinstall the firmware?"
Then after Apgoee suggested I replace the digilink cable I wrote this;
"I did actually have another digi cable and swapped it out. Strangely enough, since I had that day of errors; reinstalling PT numerous times, the rig has completely behaved.
Considering I could boot up 7.4.2 on a g5 without problem, for me anyway, dismissed the hardware problem. But I did my due diligence."
I haven't had any problems since. I don't know what fixed it, or what the issue was. But persevere, it does eventually work.
Pro Tools Ultimate 2023.12.1.138 | Mac Studio M1 Max (64 GB) | Ventura 13.6.3 | Clarett+ 2Pre
Pro Tools HD 9.0.6 | HD6 PCIx | Mac Pro5,1 (mid 2010) Westmere 3.33 GHz Hexacore (32 GB) | Lion 10.7.5 | Magma PE6R4-I | 192 i/o |
Pro Tools HD 9.0.6 | HD3 PCIe | MacPro5,1 (mid 2010) Westmere 3.33 GHz Hexacore (32 GB) | Lion 10.7.5 | Apogee Rosetta 200 | C|24
Old 06-11-2011, 11:20 AM
Sorry, I didn't really get this: do you say that your Rosetta works with Pro Tools 9 after you connected it to a system with Pro Tools 7.4?
Old 06-11-2011, 12:13 PM
zakco zakco is offline
You may want to post this in the PC forum instead...just a thought.
Old 06-11-2011, 02:32 PM
I thought about it, but then again I'm running Mac OS, so I left it here. ;-)
Old 06-11-2011, 03:22 PM
Exclamation Re: Pro Tools won't recognize my Apogee interface
We have a Rosetta 800 with an X-HD card and it works with v9.0.2. We have had a few issues with Pro Tools not recognizing it on occasion. We think we have this narrowed down to setting our SYNC HD to Video Ref before launching Pro Tools. If we don't manually set the SYNC HD, Pro Tools does not recognize the Rosetta as being connected.
Old 06-11-2011, 03:48 PM
No, it wasn't because I booted into 7.4 that 9 worked. It was concurrent but unconnected. It just helped me establish that the hardware was good. So, to be clear, for a time I could boot in 7.4 on my PPC, but 9.0 on my MacPro wouldn't recognize the Apogee. I never reinstalled the Firmware, but here's an unscientific list of what might have played a part in my MacPro eventually working.
  • Apogee hardware reset
  • Changing the Digilink cable
  • Reseating or swapping Magma cards
  • Reinstalling PT 9
  • Upgrading PT 9
  • Rebooting, restarting, permissions and all other PT troubleshooting
  • Fully unplugging both the Apogee and MacPro from the mains
  • Zapping PRAM, seating and reseating RAM
  • Making a cup of tea
I do not know which of the above actually fixed the problem. I was intending to email Apogee to detail my fix, but I still don't know what got everything working. What might help you to know is that once the problem was fixed, it did not reappear. Since mid March the rig has been booted numerous times every day, loading maybe ten to fifteen sessions per day, all without (this) issue.
Hope any of this helps.
Pro Tools 9 HD won't recognize my 192 interface innerbooty Pro Tools TDM Systems (Mac) 12 11-17-2013 01:39 PM
Pro Tools Express doesn't recognize interface jco5055 Pro Tools Express on Windows 2 02-11-2013 08:19 PM
PRO TOOLS 10 + HD2 + 96 IO interface not recognize eliomusik Pro Tools TDM Systems (Mac) 14 09-28-2012 11:34 AM
i can't get pro tools 9 to recognize my audio interface jackshocklee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 41 05-04-2011 10:35 AM
Help, pro tools will not recognize audio interface pervythemilkman Pro Tools 9 2 12-21-2010 02:34 PM
