i can't get pro tools 9 to recognize my audio interface
i can't get pro tools 9 to recognize my audio interface. Whenever I enable record, I only get a mic input feed from the internal mic from my iMac. How can I switch the input to go to my 002 input?
Also, in order to hear my sessions from Pro Tools, I have to have "alt src to mon" button pushed in. Jack Shocklee iMac i7 2.93 / 16 GB RAM |
Re: i can't get pro tools 9 to recognize my audio interface
Setup: Playback Engine: Current Engine Dropdown Window?
Apologies if you've already checked that. |
Current Engine is: Pro Tools Aggregate I/O.
The Pull Down menu has these choices: Built-In Microphone Built-In Input Built-In Output Pro Tools Aggregate I/O I've also went to SETUP > HARDWARE and configured is as best as I can, but still it seems that the input is pulling from the internal mic on my iMac. However, I do notice under Audio Devices on the HARDWARE Launch Setup App screen, Digidesign HW ( 002 ) shows no in/ no out. But Pro Tools Aggregate I/O shows 4 in / 2 out. Those 4 ins are: Built-in Microphone (2) Built-in Input (2). The 2 outs are: Built-in Output. Clock Source is: Built-in Input. |
Yes I did.
The problem is when loading up Pro Tools, it makes up it's mind to pull input from my iMac's audio drive rather than my 002. When I play a session, it never comes from the 002 audio drivers, I always have to press "ALT SRC TO MON" on the interface. I feel that's the same reason why when I press record, I get the iMac's internal mic feeding the audio rather than my mic which is hooked up to the 002. |
I would just try reinstalling Pro Tools at this point, see what happens.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Already have. Doesn't work.
Have you tried reinstalling the 002 drivers independently?
Explain what you mean independently.
Meaning, uninstall the 002 drivers and reinstall them.
Pro Tools 9 HD won't recognize my 192 interface | innerbooty | Pro Tools TDM Systems (Mac) | 12 | 11-17-2013 01:39 PM |
Pro Tools won't recognize my Apogee interface | -JK- | Pro Tools TDM Systems (Mac) | 13 | 02-19-2013 05:40 PM |
Pro Tools Express doesn't recognize interface | jco5055 | Pro Tools Express on Windows | 2 | 02-11-2013 08:19 PM |
PRO TOOLS 10 + HD2 + 96 IO interface not recognize | eliomusik | Pro Tools TDM Systems (Mac) | 14 | 09-28-2012 11:34 AM |
Help, pro tools will not recognize audio interface | pervythemilkman | Pro Tools 9 | 2 | 12-21-2010 02:34 PM |
