MBox Help
I have Pro Tools LE 7.4 and Windows XP (IE 7), and I'm having an issue with my MBox not picking up sound. I may need a driver, but don't have one for the MBox (original). Could someone shead light on this for me?
Re: MBox Help
By "picking up sound",,, what exactly do you mean???! Are you saying it doesn't record, or doesn't play? And,,,, it sounds like you don't have the original disk that comes with that Mbox? Maybe need a little more info for the guys before anyone could be of any help,,,,,,,,,,, Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
Re: MBox Help
I mean, it won't record. The LED isn't indicating it's picking up any input. Playback is fine (which is weird). Please tell me what more info shall I give so I may recieve help? Also, no I do not have the original drivers for the MBox. As I stated, I now have PT LE 7.4, and when I got the MBox it was for LE 6. Would that matter? If not, what could be the issue?
Re: MBox Help
Are you assigning the correct input for the Track? Are you record arming the Track? What is the position of the Mix Knob? Do you have anything plugged in that you are recording from, like a microphone? If it's a mic, is it a condenser? If a condenser, is phantom power turned on?
I could continue, but I think you get the idea. We need to know what your set-up is and what you have done/tried - in detail - to be able to assist. Cheers,
Re: MBox Help
The issue is like this: my mic is plugged into my mixing board, and the MBox is as well. I can record using another software, but PT won't record. I've created a track (stereo). My phantom power on my mixer is on, I tried it on the MBox as well. Yes, my mic is a condensor mic. I've been doing what I've always done to record, but now it's not recording. Nothing has changed but the software upgrade.
Re: MBox Help
Well, since no one has a clue to what I'm talking about. Why would PT playback and not record (let's start with that)?
Re: MBox Help
You're not really helping us out much... "doing what I've always done to record" is pretty vague.
Why a stereo track... you don't have a stereo mic do you? Weed's questions were spot on... Quote:
Plug your mic into Mbox input 1. Enable the Mbox phantom power. Set the Mix knob at about 12 o'clock. In Pro tools, create a MONO audio track. Assign the input to that track to Mic/Line 1. Record enable the track. You should now be able to see meter activity by turning up the gain for input 1 on the Mbox. Let us know what happens. |
Re: MBox Help
Just another thought...I've read where other people were wondering why their microphone wouldn't record anything when plugged in via XLR into the Mbox. If this is an MBox 2, and you are trying to use Mic input 1, make sure you don't have anything plugged in to the DI/Line inputs of Mic input 1, and likewise for input 2. That will disable the XLRs. And also another dumb thing I did was that I forgot I had something else in the signal path that wasn't power on. Check and make sure every piece of gear in the signal path is up and running.
Mic --> Mixer + Phantom Power --> Mbox. Hope this helps. |
Re: MBox Help
Kinda difficult to do considering I have a condensor mic. Ok, looking at my software, under "Setup". What should the I/O settings look like? Under 'Preferences' what should that look like?
Keep in mind, I have an 8-channel Beringer mixing board (MBox plugged into there (ch.3+4) Mic, plugged into channel 1). Anyone? |
Re: MBox Help
Try this for now: Just plug your mic directly into the mbox (btw...is it an mbox2?) Turn on the phantom power on the mbox Create a mono track in Pro Tools For that track's input select the input the microphone is connected to Arm the track for recording (you should see the meter start picking up what the mic is 'hearing') Turn your mix knob to about 12:00 Test the mic. Make sure that the pad isn't activated on the mbox, or the mic if it has one. This will help you hear it better. This should get the mic working. If it does, then bring the mixer back into the equation.... Quote:
The way that's worded doesn't sound like the signal flow is right. It should be: Condenser Mic -->Mixer (turn on48v) out from mixer--> mbox (input to mbox) -->Then send your 'monitor outs' on your mbox through you mixer if that's where you have your monitors hooked up, otherwise just send the monitor outs straight to the monitors. Once that signal flow is straightened out follow the same instructions above in pro tools about creating a mono track and setting its input and arming it to record. |
Updated Mac Drivers for Mbox, Mbox Pro and Fast Track Ultra now available | Avid | Technical Alerts | 0 | 10-30-2012 04:24 PM |
Mbox mix knob always plays a drum track,Mbox 2 and Pro-tools LE 8: | Haezel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-20-2011 02:58 AM |
Digi Tech Suppport? Pfft!!! Mbox/Mbox academic Questions | WestPhillySoulzition | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-17-2008 01:03 PM |
Mbox 2 Pro vs Mbox latency - Mbox 2 Mini pro? | marcnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-28-2006 08:18 PM |
Mbox - Routing the computers audio through the mbox ie. CD Rom, system sounds | brownmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-30-2003 03:22 PM |
