Audio drive not visible in browsers!
I think this is since 10.4.3 uodate? my audio drive is on the desktop and working fine, no problems, but it is not showing in the browsers? i have checked permission etc. Any ideas? Chris
Re: Audio drive not visible in browsers!
I am on 10.4.2 PT6.9.3cs3 and I have the same problem, ie sometimes (not always) if you plug in a drive (eg flash USB or firewire), the drive mounts on the desktop but does not mount in the workspace. Consequently you cannot bounce to that drive, import from that drive etc etc although it does appear in those dialog windows - you just can't access it- like it's greyed out. Similarly if you try to double click to open a session from the new drive, nothing happens. Quit Tools and reboot Tools and it's fine.
Yes, this is a known issue and is being worked on.
For now, quitting and relaunching Pro Tools will mount the drives correctly in the Workspace. |
Avid Core Audio not working with only Quicktime, iTunes, browsers, etc | seoulcube | macOS | 2 | 11-07-2014 02:37 AM |
Questions re: PT Browsers | psi777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-16-2008 11:05 AM |
Browsers problem :) | DarkoQ | Pro Tools M-Powered (Win) | 1 | 08-06-2008 01:25 PM |
Web browsers and digi core audio manager | frozenintime | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-01-2007 09:46 AM |
audio is visible; will not play back | sidereal-studios | Pro Tools TDM Systems (Mac) | 7 | 12-28-2001 04:53 PM |
