Old 06-25-2007, 04:53 PM
Chris7514 Chris7514 is offline
Default Aux input channel issue with M Box.PLEASE HELP !!!
Hi everybody !
I have got an issue, that I cannot figure out how to solve. I created a single Aux Input mono track in one of my BGM sessions. I assigned input to Mic/Line 1, and output to Analog 1-2. I plugged a single microphone to input 1 of the M Box, set the appropriate volume, and panned it to the center. The signal is coming out only of the LEFT speaker. WHY ? I tried to play with the pan slider. Nothing helps. The mono signal is NOT coming out of both speakers centered. I need to take my M Box to the gig on Thursday. The vocalist an I will be doing some kind of a demo, promoting using Pro Tools on the gig ,as a live recording tool. I will be playing accoustic grand piano along with Pro Tools sessions (as our BGM tracks), and she will be recording live. Both the audience and I need to hear a vocalist in BOTH channels centered. This same kind of a situation happened to me before with my Digi 002 R. The microphone signal was coming only out of one speaker. Please help, if it is even possible to plug one single mic and hear it coming centered out of BOTH speakers ? Any suggestions deeply appreciated !!!!!
Chris7514
PT 7.1.1, Mac BookPro, 2.16 GHz, 120 GB external EZ Quest fire wire HD, 2GB RAM, original M Box, OS X 10.4.9. SHURE Beta 58 A wireless. Everything works perfectly well...
Old 06-25-2007, 05:24 PM
JeorgeRec JeorgeRec is offline
Default Re: Aux input channel issue with M Box.PLEASE HELP !!!
try to change the speaker cables,sometimes when you have problems like this it is just a matter of simple thing like a bad cable.
Old 06-25-2007, 05:25 PM
cabuford cabuford is offline
is your input/playback knob on the mbox turned to input?
QS G4 Powerlogix Dual 1.6Ghz 1.5GB RAM
Digi001 10.3.9 PT 6.4
Powerbook 1.5GHz 1.25GB RAM
Old 06-25-2007, 06:04 PM
Thanks !
That was a problem. Turning the knob clockwise puts the signal in both channels. It's actually completely independent from software settings ! Cheers !
Chris
SC48 Flex Channel & Fan Issue Issue toddbuckner VENUE Live Sound Systems 2 03-01-2014 12:51 PM
Input Channel messed up jailbreak macOS 0 03-28-2013 06:51 AM
32 Channel Input / 16 Channel Output Device(s)? tcstx Pro Tools 9 33 02-07-2011 03:04 PM
Strange CoreAudio issue - right channel information getting into left channel -JK- Pro Tools 9 5 01-10-2011 08:42 AM
Channel Input cxbrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-26-2000 06:36 AM
