Adjusting automation between break points question
Adjusting automation using the selector tool to drag the line between break points! when the automation line is of all equal volume and you place the selector above the line then only that section is selected for adjustment, but if the line is NOT of equal volume, it selects the entire tracks automation!! is there a reason for this or what is the work around when you want to select just that portion of the region! Chris
Re: Adjusting automation between break points question
anyone?
To adjust automation for a certain portion you need to select the desired portion with the selector tool, then adjust it with the trimmer tool. You may need to add break points at the extreme edges of the selection, (but still within the selection), to adjust the entire selection evenly. At first your post was a little confusing because you used the phrase "selector tool" instead of "trimmer tool". You need both of these tools to do the job correctly. Make sure you use the right one in each case.
Hello,
Yes your right i said selector when i meant trim tool I'll start again! I have e region to adjust, lets say one chord of a chorus i wish to take down, there are already break points where i want them, so i hover the trim tool over the region and try to pull the volume down, but because the volume at this point is not exactly even! the trim tool selects the entire tracks volume automation and not just the region/chord that i want to adjust. if the regions volume is even at this point then the trim tool selects just that region/chord for adjustment!? I can of course use the selector tool to select the region again! but if it already has break points there,s no real reason to have to select it again. So why does it want to adjust the entire region when i have tried to select just that chord/region? the only difference being the volume is not even at that point!! Chris
this won't work if you want to trim automation but it works great to write.
select the spot you want to adjust, make sure it's automation playlist is showing, adjust the control to the desired position and then hit Command / this is called "write auto to selected parameter" hope this helps. drew |
Another option is to select the portion you want to trim with the selector tool, increase or decrease the volume on the channel by the desired amount, then hit command+shift+/. If you have volume automation enabled, this will trim the automation to the new volume. |
Resolution when adjusting automation points with trim tool | mahler007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-09-2010 06:44 AM |
PT 8 Automation Break Points | myke2242 | Post - Surround - Video | 7 | 04-20-2009 10:17 PM |
Track flashing white when editing automation! break points in PT8 | crizdee | Pro Tools TDM Systems (Mac) | 9 | 01-29-2009 02:01 PM |
Automation problem with and between matching break points | crizdee | Pro Tools TDM Systems (Mac) | 18 | 08-20-2008 05:01 PM |
dragging break points | Khatru | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-18-2007 05:41 PM |
