Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 10-02-2014, 01:23 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Using S/PDIF Output with Focusrite Scarlett 8i6
I need some help getting the S/PDIF out to work in my set up.
I've connect S/PDIF cables from the S/PDIF out of the 8i6 to the S/PDIF IN on the left JBL LSR4326 and then connect a S/PDIF from the left monitor S/PDIF OUT to the right monitor S/PDIF IN. I then switched the JBL's to S/PDIF mode using the software.
Then, I selected S/PDIF Stereo out for an audio track I was testing with. Hit play..and nothing. No sound at all. Clearly there's some other step I'm missing but I can't figure out what. The PT Reference guide only talks about S/PDIF with respect to HD systems.
I have the I/O for the 8i6 set up properly...all the available INS and OUTS are showing, including the S/PDIF.
If I go back to selecting the usual MAIN outs for the 8i6, switch the JBL's back to Analog and play...its fine.
I also have a S/PDIF connecting audio out from my Motif XS8 to S/PDIF in on the 8i6, and that plays fine. I can record anything I play on the Motif using the S/PDIF out of the Motif to the IN on the Scarlett and setting up an audio track to read that input. So I know S/PDIF is working...at least on input side.
Not sure what I'm missing here. Can someone shed some light?
Thanks
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 10-03-2014, 01:13 PM
DonaldM's Avatar
Default Re: Using S/PDIF Output with Focusrite Scarlett 8i6
Never mind, I got it sorted. Just wasn't something obvious, but once I got and see it, it makes a bit of sense...sort of.
Focusrite Scarlett 18i8 kyluigi Third Party Interfaces 6 10-17-2013 08:14 AM
Focusrite Saffire/Scarlett & PT9 Question... acmost Third Party Interfaces 5 07-06-2013 11:37 AM
Focusrite Scarlett 8i6 - no inputs detected? mooquu Third Party Interfaces 5 12-17-2012 09:03 AM
Focusrite Scarlett - A Steal! RussUK General Discussion 45 05-12-2010 03:29 PM
Focusrite Scarlett justus1900 Virtual Instruments 1 12-18-2009 08:43 PM
