Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 04-09-2018, 08:36 AM
frenchman frenchman is offline
Default "Pre-Echo" Offline bounce problem
I have juste reported in "Idea scale" a problem when bouncing offline, in certain configurations the reverb precedes the source and this is a total disaster.
I though everyone should be warned : I have produced a couple of masters that way and am very angry at discovering this, since in certain mixes you won't hear this right away in the middle of everything
Below you will find a image that shows my test session so that you can eventually reproduce this
Pro Tools 2018-3, mac ox 10,12,6, Six core 3,5GHz Mac Pro
I have devised a test sessions with :
-One mono source track with a short pulse, with bus 2 send on it
-A reverb return on aux track with a D-Verb plugin
- A stereo dummy audio track with a plugin that produces a fair amount of processing delay (for convenience I used Avid's RT Flanger but it will do the same with others)
Offline bounce import track clearly shows that something is wrong, whilst real time bounce is ok
I hope this is going to get fixed FAST
Thanks for listening
Mark Haliday
Paris, France
https://drive.google.com/open?id=1D_...z1-_MDLuFecIRO
Mark Haliday
Engineer, Mixer, Writer, Teacher
Pro Tools Ultimate HDX
Mac Pro 2013 & Chassis
Old 04-09-2018, 09:04 AM
Drew Mazurek's Avatar
Default Re: "Pre-Echo" Offline bounce problem
can you post the session so one of us can repro?
www.drewmazurek.com
Old 04-10-2018, 02:07 AM
Yes sorry for that !
I didn't know how to do it, that is why I posted a link to a screen capture of the session
Here is the link to a zip file containing the session
https://drive.google.com/open?id=1ZB...hyaXTDROEAk-Px
Mark Haliday
Old 04-11-2018, 03:46 AM
Thanks for your answer,
It's below
FYI, I purposely changed the plugins to use only Avid plugins, so this is not a plugin software problem, but apparently when doing offline bounces something goes wrong in the delay compensation in the buses
https://drive.google.com/file/d/1ZBu...hyaXTDROEAk-Px
Mark Haliday
Old 04-11-2018, 05:04 AM
midnightrambler midnightrambler is offline
I've just downloaded and tried this and it's working absolutely correct here. I don't have the flanger plugin though so I substituted it for Pitch II which has a high delay compensation (4096).
http://duc.avid.com/attachment.php?a...1&d=1523444645
Old 04-11-2018, 06:01 AM
home_studio home_studio is offline
Works OK with me.
Pro Tools 2018-4, mac ox 10.11.6, Six core 3.5GHz Mac Pro
Old 04-11-2018, 07:36 AM
All good here as well, and I have all the same plugins.
www.drewmazurek.com
Old 04-11-2018, 10:42 AM
off the wall's Avatar
off the wall off the wall is offline
It's below
I get the exact same (WRONG) result as you. Reverb is pre the source on the offline, OK on the realtime.
Weird.
https://drive.google.com/file/d/1Can...ew?usp=sharing
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, AMD 7970 GPU, SSD boot drive on 6Gb/sec PCIe card, 64GB RAM, MacOS 10.14.6.
Pro Tools Ultimate 2020.11. HDX, UA Octo PCIe cards, HD I/O, C|24 control surface.
Mostly Avid, Waves, Sonnex and UAD Plug-ins
Genelec 1031AP/7070A 5.1 monitoring.
Old 04-11-2018, 12:17 PM
BScout BScout is offline
I think this might be an HDX thing. For those without issue, were you non-HDX?
I'm seeing the same bug but I think(?) I know why.
First off, the Dverb plugin can be anything (including an EQ or bypassed Dverb) and it'll still do it but then you can clearly see the distance between "clicks".
Second, the Flanger channel is sending a stereo signal into a mono (sub path) bus (Bus 2). If you change that bus to a stereo bus (Bus 1-2), the problem goes away. I think what we are seeing is delay comp only happening on one leg of the bus (bus 2) while bus 1 is staying undelayed. But since we are going out center pan, it ends up looking like the undelayed signal and the delayed signal as two clicks with distance between them (the lack of delay on A1 path preceding the delay comp A2 path)
And the reason I think this is an HDX thing is HDX online uses the DSP mixer but offline uses the system processor. So "native" users are using the same mix engine whether offline or online and it is passing the delay comp info for both paths but HDX users are switching engines where the info isn't getting passed.
Tested the theory and that's what's happening. If you change the source to a stereo (duplicate mono audio file into a stereo track and keep them hard-panned, you can see the right channel delay comp correctly and the left not)
Pro Tools Ult 2019.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 04-11-2018, 12:22 PM
I don't think anyone has seen this bug before because it is really odd (with tons of uncertainty) to route a stereo channel to a mono bus on a send.
"Bounce To Disk" Track is "Lower in Volume" LSNY Pro Tools 12 18 06-05-2017 09:45 PM
"Unable to bounce offline" fcamardella Pro Tools 12 6 11-25-2016 05:36 PM
offline bounce from Send or Track outputs - track "freeze feature" OliverH Pro Tools 11 20 05-25-2014 05:45 PM
"bounce to disk" stutter problem calden Digidesign Hardware & Software 2 07-06-2003 05:42 PM
What's the difference between "online" and "offline" editing ? stuu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-21-2002 04:46 PM
