Memory Issue
Anyone seen this? When I go to launch ProTools it tells me that the playback engine needs more memory allocated and opens the PB engine dialog. On any setting I try, it tells me that "ProTools encountered an error while attempting to adjust your system memory settings." I've tried the handy delete tool, reinstalling ProTools 7.4cs7 all to no avail. I've got 6 GB of memory and I have the problem even when no other program is running and I've newly restarted the system. Any one else seen this? There's plenty of room on the system drive too, not that it should have any effect. The only thing I can think of is that there was a security patch I put in last week but I'm not sure how to go backward from the patch, if that is the problem. I would think that others would have the problem too if it were the patch causing the problem.
Dual 2.3 Mac G5 OS 10.4.11 |
Re: Memory Issue
Tracey - Hang tight a bit and I'm going to get you a script that should fix this.
If you can give me an email address to send it to, that would be great. Make sure to 'codify' it so that it can't be harvested by spambots - use something like : email [at] mydomain [dot] com. |
Re: Memory Issue
You can email me at tlarvenz at gmail dot com. Thank you!!
Re: Memory Issue
We just sent it! Let us know if it works properly or not.
Thanks! |
Re: Memory Issue
That did the trick! What corrupts the drivers? BTW, you guys might want to put this into the Answerbase. I did a search there and came up dry. Thanks very much for your help!
Re: Memory Issue
scott [at] scottgreiner <dot} com Thanks! |
Re: Memory Issue
would this be a possible fix for out of memory errors on PT 8 in 10.5?
Re: Memory Issue
PT crashes to PT8cs1 well because of thread error 0x0.
MacPro3.2G 12G Ram OS10.5.5 |
Re: Memory Issue
Where's this script at?
I've been round and round with this! The only thing that fixes it is (was) a full-reinstall. send it here!
... but does it help the chorus? Last edited by DigiTechSupt; 02-23-2009 at 03:19 PM. Reason: removed email link to stop spambots. |
Re: Memory Issue
Me too, please!!!!!!
thorsten [at] studiop4 [dot] de Thanks in advance so much. |
Memory usage in lion issue | crizdee | Pro Tools 10 | 3 | 01-05-2012 09:49 AM |
Presumably a memory issue? | jimdpie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-15-2011 07:29 AM |
Memory Location Window issue | OliJ | Pro Tools TDM Systems (Mac) | 0 | 04-08-2011 10:36 PM |
System memory issue ... OS X | SPC | Pro Tools TDM Systems (Mac) | 1 | 06-07-2003 03:34 PM |
Minimum memory issue | clutch | Pro Tools TDM Systems (Mac) | 1 | 12-04-2002 12:12 AM |
