Re: 5.1 layback to video file
The limitations of the free version relate to resolution (UHD is the maximum) stereophonic (3D) and some of the visual effects. |
Import video, import audio, place on a timeline (ensure frame size and rate matches, and your audio output bus is wide enough), choose output settings for all your desired export formats, sit back.
So are we talking manually assigning the correct channel layout for 5.1 or does it just do it automatically? I can't see anything in the Deliver section of Resolve about changing channel layouts.
PT Ultimate 2021.3 | macOS 10.15.7 | Mac Pro 7,1 michaelfbates.com imdb.com/name/nm4876413 |
how about
a) printing inside PT, then re-arranging channel order in pt (split into mono, rearrange, drag on a 5.1 track), then bounce to QT b) if you have to do this often, set up an extra 5.1 'laydown to video' bus. Make sub paths in I/O for both your master output and you laydown bus. Reroute using auxes. ? Last edited by yoerik roevens; 06-27-2017 at 06:51 AM. |
DNXHD+ProRes is only with high bitrates( >440Mbit/s) for more re-encodings processes usefull! Lower bitrates brings a bad quality!
DNXHR is better or ideal, but use a low compression ratio with a high bitrate with big files! :) |
So I have the attention of the Telestream team that makes Switch. They seem genuinely interested in the audio post-production workflows that we deal with. Go check out Switch 4.0 and then maybe add your input here:
https://telestreamforum.forumbee.com...ature-requests I'm excited about Switch as an all-purpose media player in the pro studio. It can play MXF files, RF64 WAV files, all the standard surround formats. It has the potential to do a real audio re-wrap, it can also do the channel assignments we're talking about. Check it out and let me know what you think: https://www.telestream.net/switch/overview.htm As long as they put all of our features into the mid-priced package.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
thanks, rich
Logged the Ideascale bug here: http://protools.ideascale.com/a/idea-v2/275038
Hi, I use this code to do so with ffmpeg:
Code:
ffmpeg -i video.mov -i audio.L.wav -i audio.R.wav -i audio.C.wav -i audio.LFE.wav -i audio.Ls.wav -i audio.Rs.wav -filter_complex "[1:a][2:a][3:a][4:a][5:a][6:a]amerge=inputs=6[aout]" -map 0:0 -c:v copy -map "[aout]" video_with_51aac.mp4 explanation: ffmpeg -i video.mov -i audio.L.wav -i audio.R.wav -i audio.C.wav -i audio.LFE.wav -i audio.Ls.wav -i audio.Rs.wav this part tells ffmpeg which files to use as input. I have previously moved in terminal to the folder so the full paths are not necessary. -filter_complex "[1:a][2:a][3:a][4:a][5:a][6:a]amerge=inputs=6[aout]" This part internally merges the 6 audios and calls it "aout" -map 0:0 -c:v copy -map "[aout]" This part defines the contents of the output file. First, 0:0 is the video stream of the video file. -c:v copy means "codec video copy", no reencoding. Secondly I map the previously merged audio. video_with_51aac.mp4 Finally the output filename. Using the extension mp4 will force that the audio is encoded in aac by default. Notes: 1. This assumes you don't want to reencode video, the input already in h264 quality you want to preserve. if your video is Prores or similar, leave out the -c:v copy statement and ffmpeg will reencode to h264. 2. The video stream of your particular video file may not be 0:0 like in the example. you can find out by typing ffmpeg -i video.mov and examining the result. Hope this helps |
Does it default to 384kbps in your example ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
More than one video file in PT9 video track | ricardo.sousa | macOS | 6 | 02-07-2011 10:22 AM |
Can u layback to P T and video deck at the same time? | not2tech | Post - Surround - Video | 1 | 12-04-2009 02:35 PM |
Dolby E as files for Video House Layback | EarHole | Post - Surround - Video | 4 | 12-22-2008 01:45 PM |
getting started in PT layback to video / need guidance | joewolf | Post - Surround - Video | 19 | 06-23-2008 01:30 PM |
Opinions... Video doing Audio Layback | Sonsey | Post - Surround - Video | 8 | 09-24-2004 09:48 AM |
