Slow PAL Sync?
I'm about to get started mixing a PAL 25fps short film. Client is exporting OMF out of Final Cut, and will provide a Quicktime for me to work with. The client will be transferring at some point to HD, and I was going to provide AIFF files. The post house doing the transfer said to make sure the audio was "slow PAL sync". And that the audio people should know what that is.
OK, I routinely expect the video guys to know more than they appear to, but they've got me stumped on this. This is my first PAL project, and I have no idea what "slow PAL sync" means. Anyone? Thanks. Bill |
Re: Slow PAL Sync?
I have not heard that term before. Shoot at 25, transfer to film and project at 24?? I've heard of people shooting at 24 and transfering to PAL, but not 25 to 24.
Call me by my real name, "Postman" |
Re: Slow PAL Sync?
Slow PAL is used when you need to stay NTSC but the PAL video cannot, for some reason, be actually converted to NTSC. Instead the PAL video is played back at 23.976 frames per second and a 3/2 sequence is added to make an NTSC version. |
Re: Slow PAL Sync?
In other words... normal .1% pulldown, right?
Re: Slow PAL Sync?
from 25 to 23.976? isn't that as we learned, 4.272%? or am i confused?
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Re: Slow PAL Sync?
Eric Lalicata C.A.S. Supervising Sound Editor Re-Recording Mixer Anarchy Post 1811 Victory Blvd Glendale, CA 91201 818-334-3300 www.anarchypost.net |
Re: Slow PAL Sync?
yeah, i remember that one as it was me who got you guys to correct me.... but what is the difference between what you are saying and what todd says?
Re: Slow PAL Sync?
So in response to Digibill, slow Pal is cool video guy way to say, work with your PAL speed audio in a pulled down session to match the NTSC video. Pulled down by how much? See the thread above.
This way, the post transfer house (or whomever does the printmaster) can simply remove the pulldown and all should play in sync with the PAL masters. If the quicktime from FCP is 25f pal, then I'm not sure why you would need to do any of this? Just work to the quicktime. Unless there is more info that we are not being told, this is what should work.
Re: Slow PAL Sync?
Re: Slow PAL Sync?
GOT IT! thank you!
Slow startup / Slow opening sessions | MrSoliman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-21-2018 12:45 AM |
athlon 1.2 ghz for digi 001, 5.3.1? SLOW,SLOW,SLOW | hitwriter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-19-2005 08:55 PM |
Slow computer? 1.8 ghz, 512 ram, still slow | musbkc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-29-2003 06:53 AM |
slow, slow, slow, slow... what's up digi? | Steve Moore | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-14-2003 12:56 AM |
Digi Webmaster - SLOW, SLOW, SLOW... | lwilliam | General Discussion | 5 | 04-25-2000 11:02 PM |
