Old 10-25-2011, 09:15 AM
wullie wullie is offline
Default Pro Tools 10 not opening stuck on initializing machine control!!
Pro Tools 10 not opening stuck on initializing machine control!! I have seen that this happened to some with PT 8 too, the fixes suggested have not worked. Any ideas?
Old 10-25-2011, 01:11 PM
DigiTechSupt's Avatar
Default Re: Pro Tools 10 not opening stuck on initializing machine control!!
Do you have an auth for Machine Control? If not, remove the Machine Control bundle from your Pro Tools folder.
Avid Audio Tech Support
Support FAQ
Old 10-25-2011, 03:16 PM
I do not see a machine control bundle folder, I see a controllers folder that has various things in there including motormix and HUI which I have used in protools 9.
Old 10-25-2011, 06:20 PM
I removed the controllers folder from the protools folder under applications, all this did was cause protools to not even launch. I put the controllers folder back and still failed to launch.
Next I did a complete uninstall of protools 10 and then reinstalled.
Tried to reinstall and installation failed, restarted mac and tried reinstall again, success this time.
Started protools again and I am back where I started, freezes on machine control initialization and I have to force quit.
So I am out $300 and I have no working DAW as my previous installation of 9 was uninstalled. I need help with this.
Old 11-20-2011, 08:39 PM
kbrewer kbrewer is offline
Did you ever get an answer to this? I am also getting stuck on "Initializing Machine Control." Thanks,
I can't open Protools 8; stuck on Initializing Machine Control ashtyn.eb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-25-2009 03:07 PM
Pro Tools 8 LE not opening stuck on initializing machine control!! digartisan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-29-2009 04:33 PM
Pro ToolsLE 8 stops loading at '' initializing machine control'' Stamak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-09-2009 05:40 PM
PTLE8 can't startup on "initializing machine control King Kong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-26-2009 04:06 PM
PT LE 8 new simptom - hangs on initializing machine control music project 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-23-2008 11:41 AM
