Old 05-12-2001, 11:56 AM
Xopher Xopher is offline
Default Import and Convert
I noticed that 5.1 has lost the very handy "Import and Convert" option.
The only way I was able to get 48K audio into my 44.1K session is to put the audio into an other session and import the tracks. Then it converts the sample rate of the audio files.
Is this the only way to get the files converted in 5.1?
Xopher
Old 05-12-2001, 01:10 PM
Default Re: Import and Convert
Yes, one would think that. But that is not the case. It will import, but not convert sample rates and as a result it sounds slowed down.
Xopher
Old 05-13-2001, 12:07 AM
nozza1 nozza1 is offline
The "Import and Convert" option has simply been added to the Import Audio command. Sample Rate and or File type conversion is all directed inside this window. Functions the same way as the old command in a new window. Think that's what you need to know, good luck.
[/B][/QUOTE]
Want to Import Wav - Not Convert Galadriel Windows 1 04-27-2012 09:37 AM
import and convert stevegalante Pro Tools TDM Systems (Mac) 2 11-13-2008 04:39 PM
convert+import ? 44.1>48 ? itz Pro Tools TDM Systems (Mac) 1 03-19-2002 09:14 AM
SD2 import and convert? Lord Humungous 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-09-2001 10:24 AM
5.1 - Where's Convert and Import?? jdh95 Pro Tools TDM Systems (Mac) 3 03-22-2001 09:46 AM
