Old 06-22-2001, 08:52 PM
clarkepr clarkepr is offline
Default Enabling DMA?
I am trying to set up my Windows 98se for the Digi001. I am told in the manual to "select DMA option for all IDE drives". However, when I go to the Settings tab in Device Manager, no check box for DMA appears. I am using an Intel Pentium III 900 on an Intel D815EEA motherboard (815e chipset), with 256meg memory, and 20gb 7200rpm Seagate Barracuda hard drives. Do I need to configure something else?
Old 06-24-2001, 03:44 PM
MRF MRF is offline
Default Re: Enabling DMA?
I don't know specifics about that board or drive. This is what you should have to do. Right click on my computer. Click on properties. Click on device manager tab. Click on the + next to disk drives (not hard disk controllers). Double click on a specific disk drive. Click on the settings tab. In the center of that window is a box labeled options with six checkboxes. DMA will be on the bottom right. If it is an option for you it will be white. If it is not an option for you it will be grayed out and clicking it will do nothing. Hope this works for you.
MRF [img]images/icons/grin.gif[/img]
Old 06-24-2001, 05:01 PM
Mark_Knecht Mark_Knecht is offline
http://www.pureperformance.com/js/showtip.asp?id=71
Old 06-25-2001, 05:14 AM
elksbestfriend elksbestfriend is offline
Hi there. What you will have to do is very simple. Just deinstall the UDMA 100 driver you installed from INTEL (lays in box with your motherboard) and use the HD as a UDMA 66 drive. After restart you will get a checkbox for DMA.
Bye elksbestfriend [img]images/icons/grin.gif[/img]
Enabling 48 tracks PT 7.4LE MotifMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-19-2008 04:42 PM
******* ENABLING JOURNALING******** basslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-04-2008 01:01 PM
Enabling Groups: 7.2 Mount Royal Pro Tools TDM Systems (Mac) 5 08-07-2006 04:02 PM
DMA enabling EejayDray 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-15-2005 09:47 PM
Enabling DMA? realsquid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-07-2000 11:13 PM
