Old 01-22-2015, 09:19 AM
HiLoc HiLoc is offline
Default input monitor / record issue
Hi from the 1st day on PT10.3.9 I have to hit the record at stop playing and start again to be able to get tha sound on input monitor.
And when I deselect input monitor I can't ear the previous recording.
I'm working on other PT10 without this issue, so I've run Tech support the re-installed PT10 again....no change
[FONT="Comic Sans MS"][B][COLOR="SlateGray"]Mac Pro Dual 6 Core Intel Xeon @ 3.46 GHz, 48Go RAM, OS 10.8.5, HDX Protools HD 10.3.10
1 x HD I/O + 1 x 192
Old 01-22-2015, 04:42 PM
Chief Technician's Avatar
Arrow Re: input monitor / record issue
Your signature indicates that you are using a TDM system with v10.3.9. If this is true, then the input monitoring bug you are describing is a known issue with v10.3.9. The workaround is to uninstall v10.3.9 and install an earlier release of v10. If I were doing this, I would install v10.3.7.
Old 01-23-2015, 02:59 AM
Default Re: input monitor / record issue
Thanks, but on my account product list I only have 10.3.8 witch I will try
Old 01-23-2015, 07:31 AM
Oups very funky to downgrade
I found finally a 10.3.7
Classical procedure un-instal PT, install, restart Mac, repair permissions, restart Mac and launch Pro Tools who quit immediately(launch then immediate unlaunch)
Do it again (Classical procedure) no succes
Install 10.3.8 same show
Run Techtool (you never know) found 34 .plist bad...trash restart Mac...The show keep going
I decide to go back to 10.3.9 and surprise pro tools launch
I will work a bit to day and have an eye on what you think about this
Also I have try to run Digitest twice same (launch then immediate unlaunch)
I have Diagnostics for digitech
Old 01-23-2015, 12:33 PM
Question Re: input monitor / record issue
Did you do a Clean Uninstall of 10.3.9?
Old 01-23-2015, 04:52 PM
Oh yes
Old 01-24-2015, 01:42 AM
Works fine after a new clean uninstaller
Thanks
Old 01-26-2015, 02:07 AM
oups I don't like mondays
Crash this morning
File Type: pdf Pro Tools_2015-01-26-110107_DJ-MP-1.pdf (53.8 KB, 0 views)
Old 01-26-2015, 07:30 AM
Eric Lambert's Avatar
Why not 10.3.8?
Old 01-26-2015, 09:41 AM
Because a chief technician Jonathan S. Abrams suggest it
audio input tracks sent to one aux track - how do i monitor JUST the aux input track? awhile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-17-2010 07:50 AM
green record button? "Input Monitor Only" stuck on bluesigns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-17-2004 10:16 PM
i want to monitor the input signal w/plugs during playback, but not record it... Joseph Grimm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-05-2003 04:20 PM
switch auto input and input only monitor with midiprotocol mmestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-27-2003 03:51 PM
How to toggle between "auto input" and "input monitor" with PC?? Camilo Orozco ProControl, Control|24, Command|8 2 04-23-2001 01:05 PM
