Old 11-20-2002, 08:52 AM
MikeC MikeC is offline
Default Waveform not displayed. Help!
This is driving me mad. I've just tried to record some audio into an existing session and can't see the audio waveform. It plays ok but all you get is the region where the waveform would normally be displayed. I can see all of the previous recorded material. I've searched but can't find anything that helps.
All that's changed since with my setup since I last recorded is that I've added a 1622 interface and installed Stylus.
Otherwise, it's a mix+, adat bridge, PT 5.1.3, G4 350Hz, 700Meg RAM.
Grrrrr. Any ideas?
Cheers,
Mike
Old 11-20-2002, 09:19 AM
Shawn Simpson Shawn Simpson is offline
Default Re: Waveform not displayed. Help!
Standard line:
Dump the preferences, rebuild your desktop, zap the PRAM, etc.
If that doesn't work, make sure the 'recalculate invalid overviews' option is checked in the preferences. Then try to recalculate the waveform overviews (select the region and go under the audio menu over the regions list).
And if nothing seems to work, reinstall ProTools and DAE. Good luck.
Old 11-20-2002, 09:35 AM
s2n s2n is offline
Make sure that you have waveform display instead of region display in the track's paramater settings. It's right there with volume, pan, mute and the rest.
Old 11-20-2002, 09:39 AM
Tbanks. I trashed my prefs and it seems to display ok now. Phew, I hate things like that.
Cheers,
M
[img]images/icons/smile.gif[/img]
where is the firmware version displayed Rectifried Pro Tools HDX & HD Native Systems (Mac) 6 08-18-2011 09:50 PM
external LTC not displayed in session tc window watkinssan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-10-2011 05:35 PM
waveform is displayed, but audio stops playing SmithLeeProductions Pro Tools TDM Systems (Mac) 3 03-27-2008 11:43 AM
Waveform Overviews displayed incorrectly Shan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-21-2007 02:41 PM
Reply Posts Not Displayed LGiordano General Discussion 3 04-18-1999 01:46 PM
