Pro Tools 8.0.4 + MAC OS X Lion 10.7.3 don't work
I bought the M-Box Mini which comes with the Pro Tools LE 8.0.4 and I have a MacBookPro with MAC OS X Lion 10.7.3, which means Pro Tools wont work. What should I do? Should I downgrade MAC OS?
Re: Pro Tools 8.0.4 + MAC OS X Lion 10.7.3 don't work
Had it happened to me, I would first check out OS specs for that version & upgrade/downgrade or dual boot from that required OS.
Yeah, I think I'll have to downgrade to Snow Leopard. That's the only way, right?
PT 8 is not supported in Lion but many people have been successful by using PT8 in Snow leopard and then 'updating' the OS to Lion. For those who start with Lion and try and install PT8 there seems a lot less of a success rate.
Hack Pro (4.2Ghz i7 Quad/16GB) PT11 / OSX 10.8.5 TC Electronic Konnekt 24D |
i would try updating to 8.0.5.
Most of the people that have a problem with 8.0 and lion are using an Mbox with a USB interface. The ones using a firewire interface dont seem to have any problems. why , i dont know. Chris
http://www.youtube.com/user/RegenerationMix http://soundcloud.com/regenerationmix http://twitter.com/regenerationmix MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7 |
It will work without any issues at all.
I have done extensive tests with the MBox2 USB and 3 Series(both USB and Firewire)and Digi 002 and 003 as well Eleven Rack. If you are wondering why would I have all of these interfaces? I am a Pro Audio Consultant for several Southern California Colleges and Universities and most of my work is configuring their Pro Audio and Technology Labs. All systems perform without problems from a fresh installation of Lion 10.7.3 Fresh PT 8.0.4 install then updated to 8.0.5 My recommendation for you all is to run a fresh installation of Lion. The overall performance of your system will increase significantly. Good luck to all! Lucas |
Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION | DESVED | Pro Tools HDX & HD Native Systems (Mac) | 2 | 05-21-2013 03:18 PM |
Will Pro Tools 10 work good on iMac with Mountain Lion 10.8.2 | DJtrademark | Pro Tools 10 | 4 | 01-15-2013 04:59 AM |
Will Pro Tools M-Powered 8 work in Mac OS X Mountain Lion? | andrewdrummer | Pro Tools M-Powered (Mac) | 2 | 08-30-2012 12:01 PM |
Can Pro Tools 10 work with Mac OS X Lion 10.7.3? | jackroylee | macOS | 4 | 05-08-2012 08:41 AM |
pro tools 10 shortcut does not work in OS Lion 10.7.2 | Cezarstudio | macOS | 1 | 12-13-2011 04:02 PM |
