PTMP - S/Mux - Lightbridge
Hi All
I have been over all the posts and there seem to be success stories with the Lightbridge and 32 adat inputs. Can anyone comment on this same setup, but being able to track 16 adat inputs at 96 via s/mux? thanks! |
Re: PTMP - S/Mux - Lightbridge
Hi Dylex,
ProTools does not support S/Mux format over fibre unfortunately. Which is a real shame as I've got a Pre which does S/Mux! Dang - stuck at 48k. However, I would rather stand corrected on the matter...and have the possibility of 96k... Mike
Qualified Pro Tools HD7 Operator |
I have a Profire and a Focusrite 26/26 that I connect via fibre and work all the time at higher sample rates. In fact I do all my tracking at 88.2k, but I have recorded at all the way up to 192K with the second interface...Now granted I was all the way down to 2 channels, but it worked none the less... If you cant go higher than 48K, it sounds like a limitation of your interface...not of Protools.
White Macbook OSX 10.5.5 2.2Ghz Core 2 duo 4Gb RAM PTMP 7.4.2 M-Audio Profire 2626 and Focusrite 26 I/O via lightpipe. Focusrite Platinum Voicemaster Pro KRK RP8's 1Tb Dual drive array. |
I use mostly PTMP 7.3.1cs2 but I think having 16 in outs at 96 KHz is ok with every version of PT as it stayes in nominal 18 in/out limit.
Pro Tools Ultimate 2022.10 Mac Studio M1 Max 32GB RAM 2TB SSD MacOS Monterey 12.6.1 RME DigiFace USB Apogee Rosetta 200 |
Thanks everyone for your input.
I'm gonna grab this Lightbridge unit and test the waters for myself. I will post my results... cheers |
PT 9 and Lightbridge | wildplum | Windows | 6 | 02-26-2011 06:33 AM |
can i sell PTMP 7.3/7/4 ilok license and still keep PTMP 8.0 license? | edgarbc1 | General Discussion | 0 | 07-17-2010 01:09 PM |
PTMP 7.3.1 cs 2 anyone? Trying for the 32I/O Lightbridge Setup | GrungeRkr | Pro Tools M-Powered (Mac) | 0 | 07-17-2009 11:02 PM |
Help with Lightbridge and PT8 | tekis | Pro Tools M-Powered (Mac) | 0 | 07-16-2009 03:00 PM |
sync ptmp/lightbridge to DVC? | Sergievsky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-04-2008 07:43 PM |
