Pro Tools and Internal Intel Mac Raid?
I just put 3x 500GB Seagate Drives in my Intel Mac Pro and Raided them 0 with 32kb sector size with Mac Disk utility. I made sure the raid was formated Mac OS Extended (Journaled) as per Pro Tools LE Setup Guide.
Pro Tools will not let me set the raid to Playback or Record.... Does any one have any ideas why or what I should do? Thanks for the help |
Re: Pro Tools and Internal Intel Mac Raid?
Sorry, I have reposted to a different section of the form... Storage Subsystems
i dont have the link handy, but Digi has said not to use a RAID configuration for ProTools.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64 Focusrite Saffire Pro 40 / Pro Tools 9.0.3 Mics, Guitars, Amps, Basses, Drums, Keys http://overtheeffect.bandcamp.com |
I've been wondering about this too. Are Digi only referring to *internal* RAID configurations? I would have thought an external RAID drive would be okay. Anyone using one?
Definitely would not recommend it & too DIGI doesn't either; but when u lose raid drives, thatz pretty much it
Two strikes first RAID Zero strike one and software RAID strike two.
RAID is zero protection and worse yet if one drive dies you lose the data on all the drives in the RAID 0 set. Hardware RAID card have their own processors to calulate the parity it write and other processing. Software RAID is using your CPU taking cycles away from app's and everything else the computer is doing. Hardware RAID is basically invisible to the computer, but software the computer is fully aware of. Last as others pointed out Digi doesn't support RAID.
Steve B. ---------------------------------------------------------------- If you think you can or if you think you can't, you're right. |
So, it seems (and sorry for such a basic question!) that really the only way for the 'home recorder' to back everything up is to attach 2 external drives, both firewire, daisy chained together, then use some syncing software like chronosync to to the occasional sync between those two drives. Sound right?
If you are looking for something that backs up simultaneously while you record, that's another story and may have a negative impact on Protools to keep both drives writting in sync while also streaming multitrack audio to the system. Plan ahead and make back up during down times.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
I've just reread my post and can see where I've created the confusion. Sorry about that. Regardless, you've provided me with a perfect answer. There simply isn't a way of backing up in real time, that works well with Pro Tools. So I need to do it during downtimes. Thanks to you both!!
Recording to internal RAID | Basslab | Pro Tools TDM Systems (Mac) | 1 | 10-09-2009 02:48 AM |
using raid 1 with pro tools | Anibal | Pro Tools TDM Systems (Mac) | 2 | 03-21-2008 08:28 AM |
P4C800-E Deluxe users....Intel Raid 0? | bigdude | Pro Tools TDM Systems (Win) | 2 | 08-18-2006 06:29 AM |
Internal Software Raid With Pro Tools | K.P. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-12-2005 10:53 AM |
When is a RAID really a RAID? Will this increase track count? | ThomCat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-25-2000 12:28 AM |
