Re: Compatibility: 0S X 10.3.6 and Pro Tools LE 6.4.
Just upgraded to 10.3.6 an hour ago, and have run several PT LE 6.4 sessions with no problems so far.
It seems to work fine, no plugin setting lost, midi set up and running ok Enjoy the music !
maxithev PT12 on windows10, MS Surface Pro ; PT11 on OSX10.11.6, MacPro |
Prockmat, I don't think you read my post right, but I actually said 10.3.6, not 3.5. Either way, you also said you couldn't get 6.4 to work on a G5 with 3.5 on it? Can you give me more specs on your computer setup? That doesn't seem right because just about everyone on this board says it works just fine, alone with many comments on this thread already!
I got my dual 2.5 G5 in today, and it shipped with 10.3.5. So I guees I'm safe, until Prockmat brought up that he couldn't get it to work. I'm concerned now...I won't get a chance to load up the system until this weekend, so we'll see I guess. The sheer amount of bug complaints about 6.7 bothers me. Plus, the new feature list (aside from Beat Detective LE) doesn't look convincing enough to me. |
I upgraded to 10.3.6 and PTLE 6.2.2 still seems to be working for me. Should it be??? I'm not so sure I want to upgrade to 6.7 after reading this thread!
-Scott
ScottFB Mac OS 10.9 PT 11.1.1 Eleven Rack |
Spicy, I confirm that dual 2,5Ghz G5 with 3.5 works fine with PT6.4.
That was my configuration until yesterday, when I upgraded to 3.6, and is still running fine with 6.4. Now, like other fellow here, I wonder if I should install PT 6.7...
#16
My scenerio was this... I was helping a friend install PT 6.4 on his new G5 which came loaded with 10.3.5. PT installed fine, opened fine, authorized fine... we could even open and play back sessions. But as soon as we tried to record, we would get DAE errors. PT would record about 3 secs of hash and then stop. Couldn't figure out why this was happening, as I'm running the exact same setup as my friend, except I was at 10.3.2. When we checked Digi's webpage, it said 6.4 wasn't approved for 10.3.5 and please continue to run 6.4 with 10.3.2. At that point I thought we'd try installing 10.3 onto his G5. That's when we found you can't downgrade past 10.3.5- without reformating the drive and starting over. Happy ending to the story: 6.7 came out and now everything works with no problems. 6.7 is a great upgrade anyway, so I recommend getting there, even if you have to spend the bucks to do so. |
#17
So the feature list of 6.7 was very convincing for me. Most of them I didn't understand how they would affect me until I got it and started using them. |
#18
Well that was a very convincing (and inspirational) schpeel, bud. I think I might reconsider in that case. For now, I'm going to stick with what I've got until I absolutely need to upgrade. Bebause with every upgrade, the potential for disaster comes even closer. Thanks for all that thorough information!
pro tools 10 compatibility | djecaron16 | Pro Tools 10 | 2 | 09-06-2013 05:34 PM |
Pro Tools 9 and M box compatibility | tombh | Pro Tools 9 | 2 | 11-18-2010 05:40 AM |
Pro Tools 8 and Mac G4 compatibility | swgerow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-23-2009 10:53 AM |
Compatibility from pro tools 7 to 6 | ped | Pro Tools TDM Systems (Mac) | 2 | 03-28-2006 12:56 PM |
M-Box to Pro Tools TDM / HD compatibility ? | SportsSounds | Post - Surround - Video | 1 | 12-17-2003 08:15 AM |
