Old 05-11-2023, 09:26 AM
its2loud its2loud is offline
Default Re: Mid Side recording question
You could try the following steps.
Create 1 aux track (Side input 1), assign the input to the mic input of the S mic.
Create another aux track(Side input 2,) assign the input to the same mic input of the S mic. Reverse the phase of this signal with the trim plugin.
Create a stereo buss with the mono sub busses. "Side Rx Buss" (Side Rx L, Side Rx R)
Assign Side Input 1 Aux output to the L mono Side Rx Buss
Assign Side Input 2 Aux output to the R mono Side Rx Buss.
Create a new audio track. Assign the input of the audio track to Side Rx Buss.
Record the signal on this track.
Old 05-11-2023, 09:51 AM
Top Jimmy's Avatar
Default Mid Side recording question
Originally Posted by Dave S. View Post
Hey Top Jimmy,
Your replies come across as combative and short. I wasn’t trying to tell you to go read the manual for the R88, so sorry if it came across that way, I meant that I could post that info if it helped since you asked how “exactly” what I was using.
Short yes. Combative no. You’re really overthinking this. I was leaving room for you to have your own epiphany rather than holding your hand.
Mid input to a mono track. Side input to a second mono track. Put a Mono/Stereo plugin on the side channel simply to convert it to a stereo path. If you use a plugin that also lets you invert the phase on one side alls the better, otherwise use another plugin to accomplish this. Group the channels if you want them to locked together. Bob’s your uncle.
James Cadwallader
Old 05-11-2023, 10:17 AM
Dave S. Dave S. is offline
Yeah, I wasn’t overthinking it. I’ll save you some time and make your job easier, feel free to ignore all of my posts from now on. The AI chat bots will be here soon enough.
Dave
Pro Tools Ultimate 2022.12 / OSX Monterey 12.6.2
Avid HD Omni / HD IO 8x8x8 / HDX Sonnet Echo Express 3
iMac Pro 3GHz, 10 Core, 64 GB
Old 05-11-2023, 10:29 AM
Top Jimmy's Avatar
I will respect your wishes but I still don’t believe you understand what I am talking about. A mono/stereo plugin is not a mid/side plugin. A mono/stereo plugin can be an eq, compressor or anything that simply converts the mono path of a mono track into a stereo path. Look in the plugin menu on a mono track and you’ll see some of the plugins listed as mono/stereo type. These simply convert the single mono path into stereo for stereo or dual mono processing.
James Cadwallader
Old 05-11-2023, 10:55 AM
Top Jimmy's Avatar
For clarity. A mono/stereo plugin triggers a feature in the Pro Tools mixer that converts a mono path into a stereo path.
James Cadwallader
  #16
Old 05-11-2023, 04:35 PM
You’re right, I wasn’t understanding what you meant, I apologize for the defensive response on my part. I was a little irked from JFreaks response and should’ve waited until it wore off. I will give that a try and see if I can make it work, thanks for the info.
Dave
  #17
Old 05-11-2023, 07:11 PM
Crank Crank is offline
That's elegant.
A good plugin choice is Mod Delay III mono/stereo. Set Left & Right MIX to DRY and Invert the polarity on one of the Input Ø buttons.
Lee
_______
PT-HDX 2023.3, S6 M10 24ch, MacPro 5,1 OS10.15.7, Symphony 24 i/o, Metric Halo LIO
  #18
Old 05-12-2023, 02:25 PM
SBP SBP is offline
Hi Back to your original question which I think was "is there a way to decode MS on a single stereo track with stock pro tools settings"
[Edit, I see now that this was not your original question, however I will leave my answer incase it helps in some way]
As far as I know this is not possible.
There are free plug ins I have used a HOFA 4U Meter, Fader & MS-Pan a fair bit.
https://hofa-plugins.de/en/plugins/4u/
Works very well.
Hope this helps.
PS Yes there are also ways to make this work with the mid side content on three mono tracks bussed to a stereo routing folder bus track as well which is how I have been managing this recently.
Last edited by SBP; 05-12-2023 at 03:08 PM. Reason: Not reading the question properly
  #19
Old 05-15-2023, 08:56 AM
Originally Posted by Crank View Post
That's elegant.
As Top Jimmy mentioned, and using Mod Delay III, it works great. Thank you!
Dave
  #20
Old 05-15-2023, 02:11 PM
Top Jimmy's Avatar
James Cadwallader
PT 2020: recording on one side only briaboy Pro Tools 2020 2 09-14-2020 04:53 PM
Sound in only one side during recording AnnieMac General Discussion 4 04-07-2014 05:42 PM
Decoding a Mid-Side recording sflood75 Tips & Tricks 3 04-28-2006 08:51 AM
Mide-Side Recording sflood75 Pro Tools TDM Systems (Mac) 5 03-28-2006 12:51 PM
BUSINESS 101 side of recording....adviced needed!! storm-01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-21-2003 09:37 PM
