can't uninstall Pro Tools First
I installed Pro Tools First, but wasn't recognizing my Focusrite 2i2, so I want to uninstall it and do fresh reinstall to see if that helps, plus I uninstalled the plug ins that come with it. Can someone help me uninstall? The option to do so is greyed out in Control Panel (idk why).
thanks, Red |
Re: can't uninstall Pro Tools First
I encountered a similar problem. This one worked for me:
1. Right-click on your start button and select Command Prompt (Admin) or Windows PowerShell (Admin). 2. In the command prompt, type control appwiz.cpl. 3. The old style uninstall screen should open, so you can select Avid Protools from the list, then at the top, select Change. 4. In the popup window, choose Uninstall. |
See if you can find the older 2i2 focurite asio driver on FO website. It should work with PT First
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Can't Uninstall Pro tools 11 | eyezayyah100 | Pro Tools 11 | 3 | 03-29-2017 12:23 PM |
How do I uninstall PT10? No 'Uninstall' option in Control Panel | epu | Windows | 5 | 06-26-2012 06:25 AM |
Can't Uninstall Pro Tools LE 7.4 | bigpete202 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-10-2011 09:11 PM |
Cannot uninstall Pro Tools | nn_ss_kk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-05-2008 02:24 PM |
pro tools won't uninstall | lite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-16-2005 07:03 PM |
