Can I change the sample rate?
Everything opens up in default 44.1. Wondering if I can change to 48.
Even when I create a new project, I'm not prompted for sample rate, etc and by default I'm at 44.1. On that note, where's a good "Getting Started" tutorial? I havent used PT in about 3 years (10yr Cubase user), and have forgotten the basics :P THANKS!! |
Re: Can I change the sample rate?
You set session sample rates and bit depth in the "session parameters" pulldown of the "Create New Session" dialog. It will be staring you in the face, click on the little arrow to expand it.
You can also do a Save Session Copy, to create a copy of an existing session with a different sample rate. All this is covered in the Pro Tools Reference Guide installed automatically with your copy of Pro Tools. And also available online at http://avid.force.com/pkb/articles/e...-Documentation. it is east to search that PDF but also worth reading sum of the chapter, it is generally well written and very useful. |
Because I don't see EITHER of those options. No "Session Paramaters" or "Save Session Copy" that I can find. Wondering now if the ability to change sample rates from 44.1 is just removed from the stripped down PT1st. |
Sorry my bad. Pro Tools | First, I think you are on your own.
Yes you can change to 48. you can actually choose from 44.1, 48, 88.2 and 96.. Just hold the "N" button on your keyboard upon starting up PROTOOLS|First to toggle the Playback Engine Toolbox Hope this one helps. Best Regards! Tope |
Did I mention that I'm on W7 PC? That said, where are we supposed to find info like this? I just browsed this entire tutorial doc, and found nothing about "holding down N" http://akmedia.digidesign.com/suppor...irst_85131.pdf Is there another document I should be reading too? Thanks. |
Hello JLiRD808 I suggest you download and install ASIO4ALL from http://www.asio4all.com if you don't have it running on your system yet. Hope this helps. Best Regards! Tope |
Can you answer the other question, about where to find further tutorial information? How much can we learn from the standard PT12 tutorials? Thanks! |
The reason for the ASIO4ALL download is to test the issue of driver compatibility. really sorry for the troubles. Regardarding The tutorial about PTF, here are some additional helpful PDFs http://akmedia.digidesign.com/suppor...uide_85130.pdf http://akmedia.digidesign.com/suppor...86314.pdf?ns=1 Hope this helps. Best regards, Tope |
Can't Change Sample Rate | KierONeil | Pro Tools 12 | 2 | 05-09-2015 10:31 AM |
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! | Nickford | Windows | 0 | 05-26-2013 11:20 AM |
Can't change sample rate | Gabriel_S | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-20-2012 11:43 AM |
Change Sample Rate? | kevinb511 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-10-2006 12:33 PM |
Change Sample Rate in HD? | Steven Sena | Tips & Tricks | 2 | 08-10-2002 06:33 PM |
