Old 10-30-2011, 12:20 AM
willowhaus willowhaus is offline
Default Re: Upgraded to 10.. now audio is distorting!
Huh. Well, I haven't spent that much time with it yet (both are actually fairly new to me). Dunno if I'm going to have the same problem with it directly selected yet.
Old 10-30-2011, 01:29 AM
RTFM RTFM is offline
Probably, hopefully not. Aggregate IO can be a bit finicky as it's having to, in software, sync up all streams from the devices that are aggregated which can lead to problems if proper sync isn't achieved.
Old 10-30-2011, 07:34 PM
typhy typhy is offline
So no one has any ideas huh?
I'll have to call Avid tmrw.
Old 10-30-2011, 09:59 PM
Mark Dann Mark Dann is offline
Did you uninstall PT first? I would try that next.
Old 11-01-2011, 03:01 PM
Did you try it with the Focusrite selected as the interface, instead of Aggregate?
  #16
Old 11-04-2011, 02:53 AM
WillFocusrite WillFocusrite is offline
If you are still having issues with your interface please get in contact with us via our contact form so we can try and resolve your problem:
http://www.focusrite.com/answerbase/en/contact.php
Many Thanks
Will
Focusrite Tech Support
  #17
Old 11-04-2011, 03:20 AM
Franco1967 Franco1967 is offline
go to Playback Engine>Host engine>uncheck minimize additional latency and if needed uncheck ignore errors. That should help. If not you should check the Audio-Midi-Setup if the Sample rates of your session and the output are the same.
MBox 2 Audio Cracking/Distorting; Nothing Works! AlexVieira macOS 4 11-09-2012 04:33 AM
Upgraded from PT 8 LE to PT 10 [NO AUDIO] REYNOVA macOS 2 09-28-2012 07:06 AM
Audio Distorting kyluigi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-15-2012 11:04 AM
import audio distorting icicle jack Tips & Tricks 3 07-20-2006 09:54 AM
C24 Monitor section distorting audio? SkylineGypsy ICON & C|24 5 09-15-2005 09:11 PM
