Old 07-02-2012, 04:14 AM
asimmd asimmd is offline
Default Waveform too Small
Hello
Could someone please tel me how to make the waveform bigger.
When I record guitar,the waveform shows a tiny dots.
If I open the track wider,it dosen't make it much better.
Thanks
Alan
Old 07-02-2012, 08:32 AM
WombatStudio.Org's Avatar
WombatStudio.Org WombatStudio.Org is offline
Default Re: Waveform too Small
Record with input gain louder to have a better level of waveform or if you just want to see it use the Command+Option+] key combination to adjust the waveform's size view.
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA
"It's not the gear ... it's the ear"
Old 07-02-2012, 09:28 AM
vocalvoodoo's Avatar
vocalvoodoo vocalvoodoo is offline
Alternatively, you can us option+shift+mouse scroll wheel.
Old 07-02-2012, 04:24 PM
albee1952 albee1952 is online now
When you record, have your meters in Pre-fade and adjust GAIN so the meters hit into the yellow.
Old 07-03-2012, 09:32 AM
The Weed's Avatar
The Weed The Weed is offline
And albee means gain at the source, not the faders within Pro Tools as they only control the monitor level when recording.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-03-2012, 10:20 AM
john1192 john1192 is offline
alan, upper left of your edit window there is a way to make the midi notes and the audio waveforms larger or smaller ... up near the grid, slip, shuffle, spot mode buttons ...
it is very disconcerting that more people do not know the simplest things in PT ... the manual is your friend ... buy your friend a beer and crack that puppy open ... you will not regret it ...
the other folks have covered how to get your input gain up ... all good advise
cheers
john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-03-2012, 04:34 PM
Cheers,
Yes yes, which is why I keep my meters showing Pre-Fader levels. I want to record at proper levels, while I mix with my ears (not meters). The only time I will select Post-Fader is to balance a bunch of similar tracks, like BGV's or a string section.
Old 07-03-2012, 05:11 PM
ha2dorff ha2dorff is offline
Question Re: Waveform too Small
john
I'm for sure the nerd that reads manuals from start to end. But one thing I have not figured out is:
How do I reset waveforms to normal?
Old 07-03-2012, 08:25 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default
In the menu bar right to the right of the grid relative grid slip mode function buttons
There are two grey buttons that have up and down arrows below them one shows an audio waveform the other shows midi notes
Click the one that shows the audio waveform up and you will see all the audio waveforms on your screen considering you're in edit screen all of those will make the waveforms bigger
Daniel
Old 07-03-2012, 10:13 PM
BoomTap BoomTap is offline
Thumbs up Re: Waveform too Small
cntrl option cmd [
resets waveform-height and nothing else
option a
resets wave-height AND horizontal zoom
cntrl option a
resets horizontal zoom and remains the current waveform-height
Waveform to Small asimmd Pro Tools M-Powered (Win) 0 10-26-2011 08:02 AM
Track waveform display volume got small obidon Pro Tools TDM Systems (Mac) 3 07-06-2011 09:30 PM
Calculate waveform - where are waveform views stored? levelaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-11-2010 07:18 AM
Track size big, waveform zoom small. Bug? ajv205 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-08-2008 02:59 PM
Small triangle in waveform Dopamine Pro Tools TDM Systems (Mac) 3 12-18-2002 12:55 AM
