distored outputs on 192 I/O
Channel two output is distorting and is also out of phase.We have deleted the prefs. and database and the problem still persists.When we routed via the I/O set up using same audio,the signal was clean.Any ideas of what we can do?
Mac G4 OSX v. 10.4.11 ProTools HD v. 7.2 |
Re: distored outputs on 192 I/O
Check your connections? To troubleshoot this, use the same mic/cable/preamp and try a few inputs on the 192 I/O. If you have a polarity issue, the first place I would look is the cable in or out of the 192. Is there a patchbay involved? Is a TRS or TT plug not seated all the way(that would reverse polarity and cut signal by 6db due to losing 1 of the balanced conductors).
Amp outputs same level as Main outputs? | DonaldR | Eleven Rack | 0 | 02-07-2013 01:50 PM |
Pro Tools 8 LE - distored audio | tprochera | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-20-2011 11:19 PM |
Apogee Duet outputs better sounding than Digi002R outputs? | Pasz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-08-2010 02:19 AM |
please help on mirroring outputs 1-2 to s/pdif outputs! | ournature | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 06-13-2007 08:52 PM |
slow distored playback problem | mazerr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-06-2004 10:52 PM |
