#191
Re: Digidesign - Coming September 23rd. Guitar players: Prepare to change your game..
I'm going to have to figure out a new little game plan with this one myself since I have HD. By far the coolest LE interface to date for sure.
AKA - EvilElfHobo Pro Tools 10 HD Native | Mbox 3 Pro | MacBook Pro 2.3 i5 | OSX 10.7.4 Pro Tools Music & Post Operator V6-8, Instructor, and Expert ICON Mixer Certified. Multi-Platinum Pro Tools Videos |
#192
I'm more interested in wiring the 11R into the 003 more or less permanently as long as I'm not giving up features.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#193
If I am not mistaken DTS has mentioned in a few threads that the only way to do this is through the inputs of the 002 or 003, whether they be digital or analog. The Eleven rack can't be used as an aggregate device. In other words, the usb only provides data, no audio, and therefore can't be used in tandem or to add I/O. Hope I explained that properly, it's late and i'm tired. at any rate if you do a search for it he answered this question at least twenty times today so it should be easy to find.
Mac Pro Quad-core 2.6, 5 gig ocz ram,1Tb hd internal, OSX 10.5.7, 2 internal Audio HD,lacie 500 gig external fw 800 drive Digi 003 rack, PT le 9.0.1, Mac Book Pro 2.4ghz I5, 4 gig ram, PT 9.0.2, Apogee duet Waves gold, and ssl plugins /Reason4 /miroslav philharmonik /stylus rmx /Melodyne /T-racks3 deluxe / Strike /Massey compressor, DTM /Sound Toys /blah blah etc. UA610 pre's / Chameleon Labs 7602mkII pre's / Chameleon labs 7802 stereo opto tube compressor/ Mackie hr824 monitors |
#194
found his answer.......
DTS- "You can use the Eleven Rack in combination with your current LE, MP or HD system, however it will not work as an 'aggregate device' - meaning that the USB connection only transmits control data and not audio streams, as it would if you were using the Eleven Rack as your primary interface. With an existing LE, MP or HD system you would connect the audio I/O of the Eleven Rack to your current interface and the USB connection to your computer. You will need the latest version update for 8.0.1, available below, to see the Eleven Rack control window within Pro Tools LE, HD or MP: http://www.digidesign.com/index.cfm?...4&itemid=39771 The updates at the bottom of this page were created to add support for using Eleven Rack with existing installations of Pro Tools version 8.0.1 HD, LE and M-Powered. This updater will only run if an existing installation of Pro Tools HD/LE/M-Powered version 8.0.1 is detected.* Eleven Rack support on HD and M-Powered systems includes the ability to control Eleven Rack via the Eleven Rack Control Window and embedding Rig settings. It does not enable Eleven Rack to act as an aggregate audio interface and pass audio up or down the connected USB 2.0 bus. In order to integrate Eleven Rack audio in your Pro Tools HD or M-Powered sessions, connect Eleven Rack to your existing HD or M-Powered audio interface by using the analog or digital I/O featured on Eleven Rack."
#195
So exactly what way do you have to connect the thing to be able to use the reamping features..? The thing I can't figure, is how do I get a clean track and a stereo effected track into my 002 at the same time? Or do I have to reamp every time to record the effected sound? I'm kind of assuming that I might have the spdif IO connected between the 2 devices for this setup... The manual is a bit sketchy about this and I feel some of the convenience of the reamping feature would be given up.. It is also confusing because the section in the manual for "Using 11R with HD or MP" also applies if you are currently using another LE interface..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
#196
Yeah thats kinda my question. Presumably you use either the XLR analogs or the SPDIF for the effected signal with is supposed to be stereo, The USB carries only data. This leaves the 1/4 inch outputs for a clean signal which are rather inconveniently located on both the front and rear panels. I'm not sure that I have that right and step by step how to would be nice as its not really covered in the manual. I have a feeling that this is not going to work as advertised.
#197
I hope Digi will clarify.. I am also a little surprised that they didn't throw a few new amps in there to entice... But then I guess all the plugin owners would have started braying... Hopefully it is updatable for future additions...???? That's another problem with doing this in a hardware box..
#198
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#199
#200
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
You see this Guitar? Ernie Ball Music Man 'Game Changer' Demo | Benoni | Eleven Rack | 19 | 03-24-2011 03:49 PM |
Guitar Players Dream Come True!!! | EvilElfBoy | Pro Tools TDM Systems (Mac) | 43 | 05-19-2009 07:33 PM |
$349 Mbox at Guitar Center! a new revision coming? | edgarbc1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-27-2005 12:35 PM |
HD upgrade confused ... and the price change is coming | nutshell | Pro Tools TDM Systems (Mac) | 9 | 06-14-2002 11:38 AM |
Cool New RTAS Plugin For Guitar Players | flashbak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-25-2002 04:03 AM |
