Pro Tools Ntive vs HD Tdm sound comparison
hi all ,
anybody have done some sound comparison between pro tools HD native (pcie card , thunderbolt , asio , ua , etc..) bouncing same session that include 8 drum tracks, guitars, bass, some keyboard tracks like piano, pad, synth sound , and voice ? how sound reverbs like the renaissance verb , DVerb etc.. in AAX compared to the Tdm version ? there are much differences ? somebody also made mixdown on digital console like DM 2000 or other digital desk , getting the tracks from PT Native with digital connections (adar,aes-ebu-) ? also links to audio files or if available youtube video would be great , thanks in advance for post . Last edited by zavid; 03-15-2018 at 05:10 AM. |
Re: Pro Tools Ntive vs HD Tdm sound comparison
I don’t think English is your first language so this may be hard to understand but a bounce goes to native no matter what. It was part of the design of AAX vs AAX-DSP. This is different from AAX vs a print down
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
As for the current AAX Native and AAX DSP variants of PT plugins, for all intents and purposes they sound identical. And Pro Tools itself DOES sound identical whether you're running it natively (PTSW, PTHD Native PCIe/TB) or on an HDX card. Hope this helps. |
whats the problem ??? the language ?? It is really so difficult for you understand : sound differences between mixing down (bouncing) same PT session (same audio tracks, same layout, same plug ins, setting included) 1 with old pro tools HD Tdm system and: the other with the AAX native version of protools without HD-HDX cards , but with the native pcie card (less dsp chips) using the Native driver , ? ? ? ? ? ? and compare the 2 stereo mixed down files (A<->B) if for you the english is not my first language , problem for me the "presentiment" is you have so baddest serious problems !!!!!!! dear Big : P.O.S. Last edited by zavid; 03-16-2018 at 02:29 AM. |
But if you did, you find that the AAX native versions would likely sound better. The 32bit float environment is the widely adopted way of mixing these days as opposed to TDM's fix point environment. |
(finally someone "problems" less) when "someone" post in a specialized place , suppose that who post in reply is "competent" about , unfortunately the supposition seem to be not a good think… (Big P.O.S. apart..) anyway : i know the differences about bit length word , but i also know that the PT-LE since Digi001 002 ,003 , mbox etc.. not sound as the Tdm cards with dedicated dsp chips , because dap processing is loaded on the d.a.w cpu , (dsp digital data compression / reduction, for avoid cpu crash at the first plug ins opening…..) and the topic of the thread is the same , LE vs Tdm topic "overlying" to Native (without dsp cards) vs. old HD tdm cards seen (the same) that the processing is loaded o the d.a.w cpu considering that the actual intel multicore cpus are much more "performers" than the old ones , and probably the actual PT Native dsp digital data compression / reduction, is more smooth than the old ones … but only the ears can say the truth ! reason why i asked (if possible) audio files comparison , and better more with video like on youtube many real time comparison between different outboards , outboards vs plug ins , different version of plug ins , etc.. can be found, unfortunately not found related , after various researches then this thread . (big : P.O.S. , apart) |
Digital audio is just math. With some simplifications, as long as you have nailed your gain staging it should sound just the same.
simple answer is yes tdm and pt native/hdx sound a bit different. its a bit challenging to really compare unless you are going through same convertors but i did it. gain staging as previously mentioned is different and you must make sure that tdm is not distorting.
as far as bouncing I much prefer bouncing to disk in hdx/native to same function in pt tdm. I abandoned btd in TDM many years ago. btd in hdx/pt native is much improved. ej |
(big : P.O.S. , apart) BScout ;^)
Drew speaks the truth here and I totally agree having gone thru the whole TDM versions from the beginning. To be honest, I don't miss those days at all. I think the AAX plugs sound better and are more stable that RTAS ever was. G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
Audacity Sound, Reaper Sound, Pro Tools NO SOUND | RoganX | Pro Tools 10 | 3 | 03-18-2012 09:06 PM |
Pro Tools LE and HD Comparison Chart? | Dizzi45Z | Tips & Tricks | 3 | 05-26-2008 12:13 PM |
MBox2 vs. MBox2 Pro. Sound comparison @44.1/24bit | floatingpoint_32bit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-04-2006 07:51 AM |
Sound Comparison- Mbox vs 002 Rack | babyalex | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-01-2003 08:42 AM |
Comparison of digi001 w/ pro tools III | Jerparise | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-23-1999 07:53 PM |
