Old 04-23-2017, 04:32 AM
staticdeathnoise staticdeathnoise is offline
Default Playlists and Loop Recording
So I have recorded a bunch of takes in loop record mode without ticking the "automatically create new playlists when loop recording" option and as a result what I a left with is one single lane of recorded audio with alternate takes that can only be revealed by right clicking on the clip and manually selecting the alternate take that I want to listen to from a list of alternate takes. This is very difficult to work with is there any way that I can expand the alternate takes into their own playlist lanes? Thanks
Old 04-23-2017, 05:32 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Playlists and Loop Recording
Manually creating new playlists and dropping audio there?
Janne
Old 04-23-2017, 05:36 AM
Stig Eliassen's Avatar
You can also select the clip, right-click the clip and set match criteria to selection, and then expand alternates to either track or playlist.
Old 04-23-2017, 08:52 AM
Originally Posted by Stig Eliassen View Post
...and then expand alternates to either track or playlist.
Ok thanks but how do I do that?
Also another weird things keep happening when I manually select the alternate takes and that is the clip just keeps adding extra takes that weren't there before and adding extra numbers to it so lets say I had a clip with 4 takes if when cycling through the alternate takes I click on the last one in the list for some reason it jumbles all the numbers and adds more takes to the list and I have no idea how to get rid of them and why they even happen. This is the strangest behaviour I have ever seen from a DAW. It also seems to offset my clip by some random amount and now the clip is late and any alternate take that I pick from it is also late. And I have no way of setting it to its original position without manually moving it.
Where can I find my playlists when loop recording MIDI? jschmidtiii macOS 5 08-25-2016 12:47 PM
Midi Loop recording and playlists. Rooxii Pro Tools 12 0 12-28-2015 10:05 AM
Loop recording and playlists frcjt macOS 2 05-26-2012 06:36 AM
Loop-recording vocals, all playlists start at zero? JonesH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-31-2010 04:23 PM
Loop Recording to Playlists Jenre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-21-2005 03:14 PM
