Old 02-14-2008, 10:22 AM
midnightsun midnightsun is offline
Default Analog insert Delay Compensation
I am still scoping out a PTHD system for my hybrid digital analog studio. I have Apogee 16 ADX and 16 DAX converters that I like (I haven't hear the PT converters). I expect to be doing a fair amount of inserting analog gear into channel strips during mixing. I understand that delay/latency compensation is automatic if one uses the Digi converters. If I stick with the Apogee converters how big of a pain is it to adjust for the delay/latency of analog inserts? It has been years since using PT and I am looking for simplicity.
If it ends up a big pain my option would be to go with the Digi converters!
Old 02-14-2008, 10:41 AM
Drew Mazurek's Avatar
Default Re: Analog insert Delay Compensation
Not sure about the Apogee but the Lynx Aurora has been design to have the exact same delay as the 192.
www.drewmazurek.com
Old 02-14-2008, 01:07 PM
Top Jimmy's Avatar
You're in luck. While the Apogee converters have slightly more delay than a 192, you can enter additional delay compensation values in the I/O setup for hardware inserts. So you can compensate for the additional I/O latency incurred, but only when using as a hardware insert.
Look on Apogee's website for an explanation and a rather vague helper app called adcalc. If that isn't clear enough, print a test signal and run it through a hardware insert to a new track and measure and calculate the additional latency and enter it in the I/O setup.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2019.10, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 02-14-2008, 10:52 PM
Thanks for the help folks,
Old 02-15-2008, 12:58 AM
With PT, if I use an analog channel insert in conjunction with plugin inserts on the same channels or within the same mixes, and if I have entered the proper numbers in the PT setup will mixes work without inappropriate channel delay/latency. Again, I am not familiar with the finer points of PT.
Old 02-15-2008, 04:57 AM
Stig Eliassen's Avatar
Yes, this will work. As long as you have set up your outboard gear properly as inserts, and have entered the correct amount of delay that your gear introduce to the chain, you're good to go.
Old 02-15-2008, 07:41 PM
kharp kharp is offline
Actually, the Apogee AD & DA16X converters are faster than the 192 so you have to add a little delay.
Also, since Apogee has released new firmware, you just enter in a delay value in the I/O setup under "H/W Insert Delay Compensation" and Pro Tools automatically adds that delay to an insert. No more adcalc.
I have saved my I/O setups so when I start a new session I just import those setups. It is actually really easy.
I am using it everyday with no problems on an HD3 Accel with PT v 7.3 and an AD & DA 16X.
Check out page 9 of the X-HD card manual.
X-HD Manual pdf
Hope this helps.
Old 02-16-2008, 11:32 AM
Again, many thanks to everyone for shedding light on this topic.
Analog Latency and Delay Compensation wedge Pro Tools HDX & HD Native Systems (Mac) 9 12-23-2011 01:15 PM
Pro Tools 9 Hardware Insert Delay Compensation with Lynx AES16e and Aurora 16 SolutionRoom macOS 0 04-08-2011 11:54 AM
Setting up H/W INSERT Delay Compensation teacherman Tips & Tricks 16 11-17-2010 03:30 PM
Analog Insert Compensation midnightsun Tips & Tricks 2 01-01-2008 01:13 PM
Hardware Insert Delay question - for analog outboard Jaylaca Pro Tools TDM Systems (Mac) 2 05-24-2007 05:50 PM
