Can i keep both PT 7.4.2 and DP 6 on the same MacOSX 10.5.3 ??
Hi there,
i am new to ProTools software and hardware and therefore need in advice of specialists, can i install PT 7.4.2 and Digital Performer 6 on the same system drive ? Will it not cause any problems for any one from those two applications ?? any know issues of keeping those tow applications together on the same drive ?? i have got PT 7.4.2 with HD2 , 192 Digital I/O ... any suggestion, please. thank you in advance, Vladimir |
Re: Can i keep both PT 7.4.2 and DP 6 on the same MacOSX 10.5.3 ??
In the past having PT and DP on the same system drive has not caused problems. In fact, usually it is possible to have both running at the same time if DP is NOT in DAE mode (open it first and select for audio engine either MOTU/MAS or MIDI only). Use internal audio or a MOTU audio interface for DP.
DP can run in DAE mode utilizing the Digidesign DSP cards and interfaces. It runs TDM and RTAS plugins in DAE mode, but doesn't do a few things that PT does- for instance DP in DAE mode doesn't support rewire. There are a few bugs in DP 6 in DAE mode- Firstly it won't bounce to disk, nor will it record a mix internally to disk (the audio file is blank). To record a mix then it is neccessary to route the mix externally, either to an external recorder/computer, or more likely just back in your interface. Also there are Graphic problems with some plugins where there controls will not show correctly on the screen. In many cases using a VST wrapped version of the plugin instead of the RTAS version will remedy the graphic problem. There have been reports of a few plugins not working i.e. VSS3. In general DAE mode in Digital Performer seems kind of vestigal, and MOTU doesn't support it very well- DP6 implemented a number of overdue DAE features, but it's been many months and AFAIK they haven't fixed a fundamental bug like not being able to record a mix internally. But as said, this should not affect having DP on the same system drive. FWIW there are reports that DP6 doesn't work with some NI plugins in Leopard on a PPC computer, though they seem to work OK in Leopard on Intel Macs. |
Thank you very much spiritG, for your description.
well , i will try to get used to PT then ... best, Vladimir |
PT 10.3.4 and MacOSX 10.6.8 | rrongman | macOS | 3 | 04-08-2013 09:37 AM |
003+Macosx | neilcash05 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-18-2008 06:15 AM |
OMS won't install on macOSX .help! | Belle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 02-24-2004 10:20 AM |
Why MacOSX? | Kenny Gioia | Pro Tools TDM Systems (Mac) | 26 | 01-16-2002 04:06 PM |
MacOSX | jduffas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 19 | 10-26-2001 12:24 AM |
